502 Can-Am weekend project update
Old Mar 22, 2005 | 07:02 PM
84rzv500r's Avatar
84rzv500r
Default 502 Can-Am weekend project update
I had half of one day over the weekend to work and I got the lower control arms gusseted with some 1/8" plate. I need to do the welding on the bottom yet.
I also layed out the front frame horn pieces to bend up on the brake. These will box in the front of the frame where the sway bar mounts.
And the big brown truck dropped off a couple of lengths of 7/8" 0.065 wall 4130 CM tubing and the Chrome Molly rod ends to make the front A arm tower brace. and a box full of 5/8 " CM rod ends seals, and half moon washers for the rear strut rods.
Old Mar 22, 2005 | 11:01 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
I am in the process of doing the same thing. Looking good. keep us posted on the progress.
Neal
Old Mar 23, 2005 | 09:33 AM
norvalwilhelm's Avatar
norvalwilhelm
Looks really good. The welding of the lower A arm channels is difficult in that oil/grease comes out of the seams contaminating the weld. I make a first pass to boil out the junk and then a final pass to fix the first pass.
How about welding a plate over the hole behind the steering box?? I actually plate over a larger section then just the hole to reinforce the frame under the steering box.
'Forget it you have rack and pinion.
You are doing a nice job.
Old Mar 23, 2005 | 09:53 AM
79VetteMike's Avatar
79VetteMike
Looks good. I'd really like to see some pictures of the car.
Old Mar 23, 2005 | 07:41 PM
84rzv500r's Avatar
84rzv500r
Thanks. This is only possible with the rersources and contributions on CF.
Look at My Corvette Photos...
http://forums.corvetteforum.com/phot...0/ppuser/53923
Old Mar 23, 2005 | 07:57 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
WOW, that's gonna look wicked when done
To 502 Can-Am weekend project update
