Searching for the answer....
Old Mar 23, 2005 | 05:47 PM
C3Muscle352's Avatar
C3Muscle352
Default Searching for the answer....
I cant figure it out.... I just recently installed headers in my '78, and replaced a few vaccume lines and such and all of a sudden 2 or 3 days after all that my car starts getting a rough idle. about every 5 sec it will jerk, a small bump as if it backfires/misfires or something and only while its at idle speed (curb idle), and it started idleing at 900rpm when not in gear. It still drives perfectly fine and i just cant figure out why it suddenly started that. any ideas ?
Old Mar 23, 2005 | 05:54 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Almost sounds as if it has a vaccum leak. Maybe a cracked t fitting when you changed the lines. It just took a little driving to make it break enough to show up in idle quality.
Old Mar 23, 2005 | 07:06 PM
fontking1a's Avatar
fontking1a
Maybe one of your spark plug leads got bumped and it's not connected to the plug properly?
Old Mar 23, 2005 | 07:18 PM
hirevroller's Avatar
hirevroller
My only guess would be that the headers have burnt a small hole in one of the boots or wires and is grounding out.
Old Mar 23, 2005 | 07:36 PM
C3Muscle352
its not the sparkplug wires or plugs, just replaced that and the coil, cap, rotor cause that was my first thought as to the problem. as far as the vacuum how would i figure out if it was that ? also cracked t-fitting could you explain what you mean by that?
To Searching for the answer....
