Frustrated
Old Mar 23, 2005 | 05:58 PM
71redskin's Avatar
71redskin
Default Frustrated
GOT a short somewhere in my 71 LS5... what would i use and how do i go about tracing it down....hate to have to tow it to a shop for something thats probably pretty simple...help!!!!
Old Mar 23, 2005 | 06:06 PM
brystheguy's Avatar
brystheguy
Umm, you're going to have to go in to a little more detail if you want any assistance. Lights, stereo, brake lights? What's the problem?
Old Mar 23, 2005 | 06:10 PM
LT4Coupe's Avatar
LT4Coupe
Post some symptoms, and you should get plenty of
good suggestions.
Old Mar 24, 2005 | 09:51 AM
jimcork1's Avatar
jimcork1
Default Pull fuses
I would use an ampmeter on the battery.. small enough to see 500 Miliamp draw. Make sure you have everything turned off including lights. Then check for current draw. You should be zero on a 71 except for the radio memory if you have digital memory. You might disconnect the radio also.
Pull the fuses one at a time and check for amp draw. After pulling all the fuses you should at least be able to find the circuit that has the current draw. This will help you to find the problem. good luck.. 99 nassau blue.
Old Mar 24, 2005 | 10:16 AM
pws69's Avatar
pws69
One of the VERY best additions to my "tool kit": NAPA Part # BK 7001084
about $34.00
It really does work!
Old Mar 24, 2005 | 02:54 PM
Boofers's Avatar
Boofers
Sounds like a shocking experience... If the problem is intermittent it could be difficult to track down but if the same fuse blows every time you replace it you should be able to find the short relatively easily. More specifics as has been mentioned.
Old Mar 24, 2005 | 04:53 PM
71redskin's Avatar
71redskin
Default frustrated
ok, i pulled the gauge panel to fix the oil and amp gauges... cleaned contacts on amp and replaced oil lines and cleaned fittings and gauge... well after i put it all back together the interior lites stay on so i played with the switch and they went out... turned the car off and the next day had no battery at all... then i replaced the light switch and bought a booster pack...hooked that up to the battery and shorted the booster pack... now i don't know how i will get any draw from anything with no battery...where do i go from here?
Old Mar 24, 2005 | 04:56 PM
71redskin's Avatar
71redskin
Default frustrated
i should add i pulled all the fuses and they are all good
Old Apr 1, 2005 | 10:34 AM
Boofers's Avatar
Boofers
If no fuses are blown then you probably have a "hot at all times" line shorting to ground. You will probably want to get back into the last area you were working, could be a pinched wire somewhere.
If the car has no power you may have blown your fuseable link, which is basically a fuse that is in line from your starter to the entire car (fuses the hot at all times lines). Trace the wire from your starter to your firewall, you'll see a bump in the wire or firewall, that is the fuseable link.
To Frustrated
