Headlight Switch
Old Mar 24, 2005 | 02:02 PM
79vetter's Avatar
79vetter
Default Headlight Switch
on a '79 how do you get to and remove the old switch?
It is tucked up under the dash pretty good. Is there a safe way to remove this?
Old Mar 24, 2005 | 02:40 PM
jdwhealton's Avatar
jdwhealton
Default switch removal
There are two screws on the left side of the dash in the door jam. Remove those and pull put on that side of the dash. Also remove the panel below the steering column so you can get a hand on the vacuum lines and press the **** release button. Takes me about 5 minutes to replace a switch. jd
Old Mar 24, 2005 | 02:43 PM
isosceles's Avatar
isosceles
The other reason you need to get to the rear is because in order to get the **** off you have to press a button on the bottom of the sitch to release it. Once the **** and shaft are out you can unscrew the bezel.
I agree, easy job.
Old Mar 24, 2005 | 09:37 PM
79vetter's Avatar
79vetter
once I push on the button on the underside of the switch, what exactly am I pulling on to get it loose? thanks
Old Mar 24, 2005 | 09:41 PM
ksbunting's Avatar
ksbunting
The dash **** that you usually turn to activate the lights. Pull it straight out.
Old Mar 25, 2005 | 07:32 AM
79vetter's Avatar
79vetter
Not sure what is going on?? I press the little button and try to pull on the **** and it won't come out...I pulled pretty hard and feel like I am going to break something...any advice?
Old Mar 25, 2005 | 09:10 AM
Vette Gator's Avatar
Vette Gator
You have to pull the switch to the headlight position, then hold the button in while pulling on the shaft. On mine, I had to pull pretty hard since I don't think it had ever been out since 1976. The end of the shaft has a double-taper, and pushing the button in moves a hoop that sits in the tapered part of the shaft and normally keeps you from pulling it completely out of the dash when turning on the headlights. It's hard to describe without pictures, but you'll see what I mean when the shaft comes out.
Incidentally, for me, the toughest part of removing the headlight switch turned out to be getting the nut off that holds the switch body into the dash. I didn't have a screwdriver with a wide enough blade to span the nut, so I ground down a washer and held it with vise grips. Took penetrating oil and moving the switch body around to get the threads to loosen.
Old Mar 25, 2005 | 09:15 PM
79vetter's Avatar
79vetter
OK I was able to get the **** and its shaft out;
Now where is this nut that you are talking about that holds the swtich onto the dash? . I only one that I can see is directly above the H/L switch but that looks like it is holding the wiper switch on...
Old Mar 26, 2005 | 01:33 AM
EVIL_GRIM's Avatar
EVIL_GRIM
Ecklers Part # A8256 thats what it looks like, get a big flat head and unscrew that to get the switch out.
Old Mar 26, 2005 | 09:24 AM
79vetter's Avatar
79vetter
Cool , I see what you are talking about now. I was looking for something on the other side of the dash...thanks
Old Mar 27, 2005 | 09:17 PM
scotty13's Avatar
scotty13
if u want to replace it cheap... go to napa for 20$.... transplant the vacume guts on the bottom.... u will see what i mean if u buy one.
Old Mar 28, 2005 | 07:00 PM
79vetter's Avatar
79vetter
Well --the good news is that I got one at Napa for $12- the bad news is that it did not solve my dashlights problem...
Old Mar 28, 2005 | 07:10 PM
isosceles's Avatar
isosceles
Here's another jumper wire test. I always make sure I have a fuse in the wire with an inline blade fuse holder.
Take a wire with 2 spade connectors on it, 4-5 inches long. plug one end into a slot on the fuse panel label IGN.. This should be on when the ignition is turned on. Remove the fuse for the dash lights. I take the other end of the wire and plug it into one side (right I think try left if it doesn't work) where the blade fuse plugs in.
When I tried this, my dash lights worked until my HL switch from Ecklers came in. They were on when ever the ignition was on. If they don't come on with the jumper and the ingnition on, you could have a circuit card problem.
Maybe someone else will contribute with more indepth problems other than the power issue I had.
Old Mar 29, 2005 | 01:32 PM
EVIL_GRIM's Avatar
EVIL_GRIM
i bought my switch from Ecklers for like 40 bucks or something, and i work at Napa and didnt even bother to look up the switch we had for like 5 bucks with my employee discount!!!
Old Apr 9, 2005 | 05:49 PM
79vetter's Avatar
79vetter
Even though I bought the new H/L switch, the dash lights still don't work.
In looking at the GM shop manual on page 8B-14, there shows to be a ground strap for the light switch. I do not see this strap at all on the backside of the light switch hole--it looks to be missing..
wondering if this is what the problem is???
Old Apr 9, 2005 | 07:48 PM
ksbunting's Avatar
ksbunting
Should be easy to confirm if this is indeed your problem. Run a temporary wire to any good ground and see if it cures the problem.
Old Apr 11, 2005 | 12:51 PM
Marv's Avatar
Marv
There is also a separate ground for just the center gauge cluster. It attaches with a screw to the birdcage just above the hood release bracket at the driver's kick panel. Good luck.
Old Apr 12, 2005 | 02:28 PM
79vetter's Avatar
79vetter
Well, I ran a wire from the IGN on the fuse panel to the Instrument Panel fuse prong and still did not get any lights on the dash. So, I have done this and replaced the light switch and still a no go on dash and center console lights. The turn signal lights work and the high beam light works. Also the interior courtesy lights work. The black ground wire is there at the kick panel ok..
Any suggestions to this one? Maybe the printed circuit? But would the turn lights work if that was bad?
Anyone have instructions on removing the printed circuit?
To Headlight Switch
