Conversion U Joint? Need help!
Old Mar 26, 2005 | 07:31 PM
Jclgodale3's Avatar
Jclgodale3
Default Conversion U Joint? Need help!
I got my C4 aluminum driveshaft today. Perfect fit for the 5 speed conversion. The U joint in the front that connects to the tranny yoke fits perfectly. The very same u Joint that goes into the differential is to narrow (between straps) Does someone make a conversion u joint to mate to the driveshaft then wider to mount to the rear yoke? If someone does, who and please...please give me a part number for the standard front yoke and the "conversion" rear yoke I need. Thanks...this thing is close to moving on it's own and this one little hang up is stalling me...
Old Mar 26, 2005 | 08:09 PM
vettepilot68's Avatar
vettepilot68
JL...what do you mean "narrow"? the U joint is not going to go to the end of the straps but should fit snug in the yoke on the diff...jk
Old Mar 26, 2005 | 08:12 PM
Jclgodale3's Avatar
Jclgodale3
"narrow" meaning outside cup to cup (of the u joint) in driveshaft is narrower than out cup to cup (of the u joint) of the diff...tranny yoke is the same as the driveshaft...does this make sense?
Old Mar 26, 2005 | 08:24 PM
vettepilot68
OK. I was just looking at the catalogs...it does appear that you rear could be different than the front...depends on the year.
Old Mar 26, 2005 | 08:33 PM
Jclgodale3's Avatar
Jclgodale3
Old Mar 26, 2005 | 08:34 PM
Sharky Guam's Avatar
Sharky Guam
I had a similar problem on a firend's car last year. I took the measurements to my NAPA dealer. He fixed me right up with the u- joints to fix the problem.
Old Mar 26, 2005 | 08:40 PM
Jclgodale3's Avatar
Jclgodale3
so they do make an adapter type u joint? say...going from a 1310 mount to a 1330 mount in one joint?
Old Mar 26, 2005 | 08:57 PM
Sharky Guam
Yes, they are made! I was lucky enough to have a NAPA dealer that obviously stocked that item. I don't know the name of the manufacturer right off the top of my head. But I would call someone liek Drive Train Specialists to see if they can point you in the right direction. Surely, there are others out there that have gone thru a similar experience.
Good luck!
Old Mar 26, 2005 | 09:03 PM
Jclgodale3's Avatar
Jclgodale3
and
Old Mar 26, 2005 | 09:56 PM
Sharky Guam
go to this website:
http://www.drivetrainspecialists.com....php?catid=133
this is Drivetrain Specialists page on conversion u-joints....
Old Mar 26, 2005 | 10:14 PM
Jclgodale3's Avatar
Jclgodale3
even er...thanks!
Old Mar 27, 2005 | 02:05 PM
Jclgodale3's Avatar
Jclgodale3
Originally Posted by Sharky Guam
go to this website:
ok...this lists conversion joints but part numbers have changed so often...what joint do I need for the rear of the shaft going into the diff? The shaft joint length is 3.250 end to end...the diff is 3.675 end to end (cap to cap) Anyone???
Old Mar 27, 2005 | 06:01 PM
Sharky Guam
try these following numbers:
Spicer PN 5-460x
NAPA 447
or go to this website to see some conversion u joints.....
http://www.arizonadrivelines.com/u-j...rsion_type.htm
Old Mar 27, 2005 | 06:10 PM
Sharky Guam
Default u joint
go to this page and see if this is what you need.....
http://www.rockforddriveline.com/Shopping/K134A.asp
To Conversion U Joint? Need help!
