Greasing brake caliper pins
Old Mar 26, 2005 | 09:47 PM
mark79,80's Avatar
mark79,80
Default Greasing brake caliper pins
When changing calipers and installing new brake pads do you put
some synthetic brake grease on the pin that holds the pads?
I ask this as I found that the corvette was pulling to one side when
braking. When I pulled the calipers and brake pads there was grease
on the brake pads. I did not notice any grease on the pin but the
last time I serviced the brakes I did put a liberal coating of synthetic
brake grease on the pin.
The only other thing I noticed are that the grease cups for the upper
ball joints on both sides have ruptured. Is it likely that excess grease
from the upper ball joints could have gotten on the brake pads on one
front brake caliper and not the other side?
Old Mar 26, 2005 | 09:54 PM
GDaina's Avatar
GDaina
The heat will make the grease flow on the pads...no grease on the pins
Old Mar 26, 2005 | 10:17 PM
marshrat99's Avatar
marshrat99
but I do wire brush the pins and put just a smidgen of anti-seeze on them.
Old Mar 26, 2005 | 10:28 PM
busterpelvis's Avatar
busterpelvis
You have a leaking caliper.
Old Mar 26, 2005 | 10:44 PM
Sharky Guam's Avatar
Sharky Guam
I agree, no grease, maybe a slight dab of anti seize though and you either have a bad caliper or a rubber brake line that is deteriorating. I once had that problem on a friend's vette. But after replacing the caliper, the problem still existed. I found out that the rubber hose was detriorating and causing a restriction to the fluid flow. After replacing it with stainless braided lines, the problem went away.
Old Mar 27, 2005 | 12:49 AM
agteacher's Avatar
agteacher
Default Sharky "G" which side??
When applying brakes----The car "pulls" to One side( for example driver side)....WOULD that side (driver side) be where the brake hose or caliper is the problem???? "IF" the rubber hose has a "restriction"....WHY does the car PULL ????
THANKS
Old Mar 27, 2005 | 01:12 AM
Z-man's Avatar
Z-man
THANKS
The car pulls to the "good" side. It's the other side that is bad and can't grip as well. Like having brakes only on one front wheel. The wheel that stops spinning will slow the car down - the other side still has momentum and wants to continue.
In your example, I'd look at the passenger side for problems since the driver's side seems to be working.
Old Mar 27, 2005 | 01:51 AM
Sharky Guam
But when doing a repair on brakes on the front, always do the same exact thing to both sides. That way, the uneveness will be prevented. You can buy a pair of calipers from Muskegon Brake here on the forum. They also sell the hoses.
Old Mar 28, 2005 | 11:27 AM
kdf1986's Avatar
kdf1986
I agree with Z-Man.
The car will pull to the good side. If the bad side has grease/oil on the pad or rotor, it will not brake. Therefore all of the braking action will be on the opposite side, and the car should pull in that direction.
kdf
Old Mar 29, 2005 | 09:53 AM
jimcork1's Avatar
jimcork1
Default Grease the pins
I have always put a film of Disc brake synthetic lube on the pins. They must be free to slide to prevent side loading of the caliper and pads. If you put a small amount there won't be enough to flow on the pads.
When I do my C5 I will also grease the pin slides. 99 Nassau Blue
Old Mar 29, 2005 | 12:49 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Corvette pads don't move ( much ) they are not like late model single piston brakes where the whole caliper has to slide around.
If you have a sticky caliper it's probably something else.
Old Mar 29, 2005 | 04:28 PM
Tom454's Avatar
Tom454
Been doing 'em for over 30 years.... no grease on the pins. The pads only move a tiny bit, and the holes where the pins ride are way over-sized. No grease needed.
It will melt & run.
If you're bothered by the rust, you can get stainless pins.
To Greasing brake caliper pins
