Source for 68 points distributor springs
Old Mar 27, 2005 | 09:45 AM
Garys 68's Avatar
Garys 68
Default Source for 68 points distributor springs
I want to recurve my the points distributor in my 68. Which distributor is it (Delco?)? Summit lists a pre 69 for Delco distributors. Will that one work?
Gary
Old Mar 27, 2005 | 10:18 AM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
It should.
Old Mar 27, 2005 | 11:18 AM
Garys 68's Avatar
Garys 68
I noticed Mr Gasket makes a 1) pre-69, 2) a post 69, and 3) a GM points distributor kit? I'm assuming #1 or #3 but which one?
Gary
Old Mar 27, 2005 | 11:23 AM
Cali,68,L-79's Avatar
Cali,68,L-79
I bought the kit from Summit. If LARS tunes your car he'll **** can yours for his homemade springs anyway. Suggest buying the SUMITT for now and later get a group together and fly LARS out. Best tuneup your car could ever ask for.
Old Mar 27, 2005 | 11:27 AM
Garys 68's Avatar
Garys 68
Cant afford LARS Not enough beer in the fridge.
Which kit did you buy? Was it springs + bushings + weights?
Gary
Old Mar 27, 2005 | 11:28 AM
Cali,68,L-79
Gary
correct.
Old Mar 27, 2005 | 11:29 AM
lars's Avatar
lars
If you have a points-type distributor, buy Mr. Gasket part number 927 or 928. Throw away the weights that come in the 927 kit - use only your stock weights. In the kits, there are 3 sets of springs and a brass advance stop bushing. Install the bushing after you whack it with a hammer on its side to make it fit tight. Then, install one black spring and one silver spring from the kit. This will give you a nice quick curve that will make your car feel very responsive.
Old Mar 27, 2005 | 11:31 AM
Cali,68,L-79
Hey LARS!
David
Old Mar 27, 2005 | 11:32 AM
PRNDL's Avatar
PRNDL
I bought a Mr Gasket kit for my 68 bigblock. I think it was the pre 69 kit but I don't remember. The weights did not fit, but my old weights seemed to be ok. There was also a bushing in there that I didn't use. There were 3 sets of springs and I used the lightest ones. I thought it was a bit expensive (around $11?) for one little set of springs which was the only thing I used out of the kit! But they did work and allowed me to bring my timing in much sooner.
Old Mar 27, 2005 | 11:35 AM
lars's Avatar
lars
Hey LARS!
David
Hi David!!! Cheers back at you!
Old Mar 27, 2005 | 11:36 AM
Garys 68's Avatar
Garys 68
Woohoo, thanks lars! I'll have the beer delivered to your door
Old Mar 27, 2005 | 11:43 AM
PRNDL's Avatar
PRNDL
Now he tells me!!! That's ok, I didn't even try to use it...
I also could have saved the 30 secs I wasted trying to make the weights fit from the kit!
To Source for 68 points distributor springs
