Gas in oil??
Old Mar 27, 2005 | 04:53 PM
Bobbyg75's Avatar
Bobbyg75
Default Gas in oil??
Have a 1975 coupe 350 and had motor gone through last summer by a reputable shop. Vette has been parked for winter storage, however I did start it up a couple times. The last time I started it, it ran rougher than hell and was running very rich. Just changed the oil to get ready for spring and almost 9 qts drained!! The oil is very thin and has a heavy gas smell. What the heck can cause gas to get into crankcase???
Thanks in advance for your help.
Bob
Old Mar 27, 2005 | 05:04 PM
Twin_Turbo's Avatar
Twin_Turbo
leaking fuel pump
Old Mar 27, 2005 | 05:26 PM
zwede's Avatar
zwede
Listen to twin-turbo. He speaketh the truth.
Old Mar 27, 2005 | 05:32 PM
PROSOUTH's Avatar
PROSOUTH
From: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
Fuel pump is not leaking........it's pouring!
The fuel pump diaphragm has burst and is allowing gas to enter the oil pan. Just one of those things that happen in a small block Chevy. j
Old Mar 27, 2005 | 05:42 PM
Bobbyg75's Avatar
Bobbyg75
Thanks for quick reply! Any tricks to changing it? Just pull old and install new? Does oil need to be drained?
Old Mar 27, 2005 | 05:54 PM
gdh's Avatar
gdh
drain it right away and do not start again until you have change oil filter and fuel pump, also check your carb to make sure it is not leaking as well. You don't want to have to totally rebuild that engine.
Old Mar 27, 2005 | 05:58 PM
Bobbyg75's Avatar
Bobbyg75
Question was more on changing the fuel pump - any tricks I should be aware of or is it straight forward?
Old Mar 27, 2005 | 06:11 PM
jdmick's Avatar
jdmick
Pretty straightforward. One tip is to grease up the pushrod so it stays in place when you put in the new pump. Be ready to plug the fuel hose when you disconnect it. That's about it.
Old Mar 27, 2005 | 06:19 PM
isosceles's Avatar
isosceles
Take your right front wheel off and access the top 2 bolts with an extension through the little slot above the frame. Makes it MUCH easier. That is one of the first tips I learned here in the forum.
Old Mar 27, 2005 | 06:25 PM
79inSD's Avatar
79inSD
I posted for advice on changing a fuel pump the other day, Lots of info on the post. If you go back a page or 2 you can find it.
Jeff
jdmick's Avatar
jdmick
Hey that's cheating.
BTW Bob I don't suppose you know of my cousin Jay Maki from Lakeville?
Old Mar 27, 2005 | 07:02 PM
carhound's Avatar
carhound
Prob. is the fuel pump, but another way for gas to get into the oil is draining from the carb. Mine needed a rebuild. If I let it run for a while and cut it off, the fuel which had been pumped into the carb would leak,I think, through the needle and seat. Don't know for sure, but just trying to help.
Old Mar 27, 2005 | 07:28 PM
Rockn-Roll's Avatar
Rockn-Roll
Yep. Fuel pump has a "weep" hole in between two diaphrams so that when the outside diaphram blows fuel will leak to the outside...the inside diaphram rarely blows, but if it does then no big deal, until the outside diaphram blows, but if the outside blows then you will see fuel leaking out of the fuel pump.
The most common reason for fuel in the oil is from a carburator needle valve which is stuck open and causes fuel to pour over the fuel reservoir and down into the cylinders. The engine will run really rough, but it will run because the fuel spilling into the cylinders is in the liquid state and isn't causing too much of a change in the air/fuel mixture up near the spark plugs unless the engine is already hot and it's a hot day.
Checking the carb is easy...just take the fuel line off (plug it so no fuel leaks out), then take a clean hose and attach it to the carb and blow into it...if you can blow into it after the carburator reservoir is full then the carb needs to be rebuilt. You can fill the reservoir manually by pouring fuel into the center of the carb around where the air cleaner stud is located (rochesters).
Old Mar 27, 2005 | 10:11 PM
Bobbyg75's Avatar
Bobbyg75
So, there is no way for fuel to drain into the crankcase through the fuel pump?
Old Mar 27, 2005 | 10:41 PM
hawgn68's Avatar
hawgn68
BobbyG,
I had the same problem with my '73 after I replaced a broken rear spindle and the car had set for 4 months. I first suspected the fuel pump, but the real culprit was the fact that I had the car jacked up with the rear significantly higher than the front with a full tank. I discovered this after pulling a few plugs and there was raw fuel in the cylinders. Newton's gravitational force (with an open needle/seat) caused the problem. Just a posibility. Good luck
Jim
Old Mar 28, 2005 | 12:03 AM
green's Avatar
green
I just changed my fuel pump this morning. No big deal, I think you guys had all the pointers covered. I did lose about a gallon of gas, and managed to get some on my head (use goggles). Question - does the oil always get contaminated with gas when the fuel pump blows, or just sometimes? After smelling so much gas today, I can't even tell right now if my oil has a gas smell.
Old Mar 28, 2005 | 09:55 AM
norvalwilhelm's Avatar
norvalwilhelm
Originally Posted by Twin_Turbo
leaking fuel pump
I had this happen twice with other motors and that is the main reason I only run electric pumps on my vet. The thoughts of gas diluted oil running through my engine until I discovered the problem still gives me night mares.
To Gas in oil??
Old Mar 28, 2005 | 10:06 AM
Grinchia's Avatar
Grinchia
I had the same thing happen with the stuck carb needle/rear end jacked up...I had gas leaking out around the dipstick sleeve where it enters the block!
I had to change the oil 3 time before I was happy that it wasn't thin/gassy...Just started and ran for 30 seconds with the fresh oil, then looked at the dipstick. If too thin or gassy smelling, repeat the oil change. You do NOT want thinned out oil protecting your crank bearings!
Old Mar 28, 2005 | 10:09 AM
Twin_Turbo's Avatar
Twin_Turbo
there's another solution, I use the seals-it seal for my pump on my truck, it keeps the hot oil away from the diaphragm and in case there's a hole in it it'll keep the gas out of the oil. I wonder why no one uses it here...or I have never heard of anyone using them, I've mentioned them a couple of times and they are really worth the money. Can't run electric on my truck as it's a dual tank one w/ a switch valve, I'd have to run another switch valve for the return line so it returns to the proper tank.
Old Mar 28, 2005 | 10:28 AM
GDaina's Avatar
GDaina
You asked if the oil has to be drained, and GDH gave you the answer.
