Question About Rag Joint
Old Mar 27, 2005 | 10:49 PM
Biker's Avatar
Biker
Default Question About Rag Joint
My Chilton's manual has no procedure for replacing the rag joint in my '81. Does replacement require removing the steering box or loosening the steering column, so the flanges can be removed from the steering shaft? Do the flanges redily separate or is a puller needed?
Old Mar 27, 2005 | 11:00 PM
74FLCONV's Avatar
74FLCONV
I'm about to do the same job. Also interested in replies.
D. Ocean
Miami, FLA
Old Mar 27, 2005 | 11:24 PM
TXShark's Avatar
TXShark
It will come apart with a screwdriver once you get it loose. Actually, pretty simple job. It only goes on one way. You disconnect the shaft from the coupler, slide it off and replace the joint. Sometimes you have to loosen the steering box to get the clearance. Your steering wheel should be pointed straight ahead so you know where to go back to. Shouldn't be a problem with the shaft being flat on one side, but mine got jacked up somehow. Anyway, it's pretty easy. There was an article in Corvette Fever a May 2002 titled Rag Joint R&R which you should get from their website that will clearly outline (with pictures) the procedure. Makes a big difference when you're done! Good luck.
Old Mar 28, 2005 | 01:47 AM
SLine78's Avatar
SLine78
Jim Shea has a write-up on the corvettefaq.com on replacing the flex coupling.
http://www.corvettefaq.com/redir.asp?site=200
Mike
Old Mar 28, 2005 | 09:47 AM
Jim Shea's Avatar
Jim Shea
The article in one of the Corvette magazines indicated that you can pry on the flexible coupling in order to gain clearance to remove it. It did not mention loosening the steering column or loosening the gear.
Prying on the flexible coupling will most likely cause the steering shaft to be forced back inside the steering column. Most mechanics will not notice that the shaft has moved. Now when a new flexible coupling is installed, it will be noticed that the coupling has to be "pulled" apart in order to span the distance from the gear to the steering column. This is not a good condition.
I strongly recommend that you do NOT pry on this connection in order to service it.
Old Mar 28, 2005 | 10:18 AM
GTR1999's Avatar
GTR1999
You also have to remove the 12 pt bolt, there is a groove in the shaft the bolt fits into so just loosening it will not solve removing it.
Gary
Old Mar 28, 2005 | 10:25 AM
GDaina's Avatar
GDaina
Prying only Bubbatizes the operation, removing the steering column bolts to move the column back an inch seems the most sensible thing to do...or you can remove the steering box bolts, but handling that box is awkward and clumsy....
Old Mar 28, 2005 | 08:13 PM
ClockworkOrange's Avatar
ClockworkOrange
Default Replacing he steering coupler
Mine was badly torn and the pins worn from having moved to far. the steering is very tight now but I had no other wear in the front end.
The part # is 7818568 and I paid 117.50 in Canada on May 18th.
You don't have to drop the steering column but you do have to remove the three bolts holding the steering box leaving the pitman arm attached. Don't take it out just remove those bolts, thats how I did it, my dad and I that is, on a hoist.
There is a master spline on the steering box and coupling so it only goes on in one way, don't force anything.
To Question About Rag Joint
