rear spindle safety question
Old Mar 28, 2005 | 08:53 AM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
Default rear spindle safety question
When I bought my 76 last summer, I drove it home 170 miles. I knew about a couple of mechanical things that needed repaired but took my time and got home. I have since noticed that the passenger side rear spindle will need replaced soon. The castlenut or the spindle itself has some stripped threads. There is about 1/8 of an inch of spindle sticking out past the end of the nut, there is a new cotter ping sticking through it. You can grab the tire (when jacked up) and you get a little play. If my wife does it while Im under looking at it, you can tell that the castlenut at least needs tightened because you can see it wiggle a little.
Here is my question, I know the spindle won't "fall off" because the cotter pin will prevent the nut from backing off, but how many folks would still go 120 miles to a Vette show you've been planning for about a year. I think I'll be just fine and plan on replacing the spindle afterwards. I know there is no way I can have it completed before I have to leave on Friday. I figure I drove the 170 miles to get it home, I'll not do any hard accelerations or fast turns etc and will be fine for an easy 2 hour drive to the show and then back.
Lets hear your thoughts, yeahs or neahs.
Old Mar 28, 2005 | 09:02 AM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
go to the show.
everyone else here will tell you to do a frame off first becasue we have a forum full of worry warts here.
P.S. Get AAA gold. They will tow you up to 100 miles. Its a must have for anyone with a C3.
Old Mar 28, 2005 | 09:07 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
The spindle nut will not sit flush with the top of the castle nut. It should stick out about an 1/8". You might want to try and retorque it to 100 ft/lbs.
Old Mar 28, 2005 | 09:08 AM
ruby76's Avatar
ruby76
That's the problem, I can't re-torque it as it spins freely. You can tell that either the spindle threads or the threads on the castle nut are stripped. So I can't tighten it any further.
Old Mar 28, 2005 | 10:32 AM
GTR1999's Avatar
GTR1999
It's very possible someone was in there before you got the car so anything is possible. I don't think the spindle will fall out but they do break/shear. Most times due to overloading but it could be due to improper setup. There's not much to the spindle. I had some that I wouldn't trust around the block,it's hard to say how far you could go IF bubba was there.
Gary
Old Mar 28, 2005 | 10:48 AM
Solid LT1's Avatar
Solid LT1
I have had the castle nuts "Crack" before. I wouldn't drive 10 miles let alone 100 miles on a compromised component but, it's your Vette. Panels are easy to replace and if you learn how to do it yourself, the job could be done for under $1,500 after the car goes back "into" paint. Do you really want to make that show? is th eplastic trophy really worth the risk? Your Vette, your choice. You can always attend and "scope" the competition out and make the extra effort for the next show.
Old Mar 28, 2005 | 10:52 AM
turtlevette
Here we go. You forgot to tell him his head is going to explode too.
Old Mar 28, 2005 | 11:04 AM
ruby76's Avatar
ruby76
Gary
Is that as far as the threads go on the spindle, that is what mine is looking like. From the looks of the picture, looks like the threads on the spindle only allow to the nut to go that far, Maybe I just need a washer to allow me to torque it down the rest of the way to let the nut get some threads.
Old Mar 28, 2005 | 11:05 AM
Fevre's Avatar
Fevre
Don't think I would risk it but if you like to roll those dice you might hit 7 or 11 but then again you might crap out.
Old Mar 28, 2005 | 11:40 AM
norvalwilhelm's Avatar
norvalwilhelm
I thought the nut spun freely on the axle if it wasn't for the cotter pin? I thought the nut or the axle was stripped??
So what is left holding the axle in is the cotter pin and the press fit on the bearings??
He would be lucky if all that got damaged was a rear fender. How about a life? His of someone elses?
If what I thought is true I wouldn't drive it until it is fixed.
Old Mar 28, 2005 | 11:41 AM
Twin_Turbo's Avatar
Twin_Turbo
I agree, even if you don't care for your own safety don't drive it for the safety of others, only the cotter pin, what's left of the threads and the bearing is holding your stuff together.
Old Mar 28, 2005 | 11:43 AM
70vert's Avatar
70vert
Banned Scam/Spammer
You say the threads are stripped? The cotter pin is only meant to keep the nut from losening, it is not and will not take much thrust load. There's no way I would drive it if it is like you described. Fix it first, it is not worth the risk just to take it another show.
Old Mar 28, 2005 | 11:47 AM
turtlevette
ruby,
do you have a firm brake pedal?
Take the nut off and try to pull the wheel out. The inner bearing should be pressed on and won't allow the spindle to walk out.
In addition to that the brake caliper will hold the spindle in to some extent.
you can attempt to see whether the spindle or nut is stripped. You could use a new nut and/or retap the spindle.
Old Mar 28, 2005 | 12:07 PM
ruby76's Avatar
ruby76
I'll check tonight to see which is stripped or if neither is.
Old Mar 28, 2005 | 12:19 PM
TedH's Avatar
TedH
Yep, we's a bunch of worry warts here. Do what you want. It's your car. Seems you are in good hands. As for me, I feel much more secure having had two bad spindles recently replaced. But I'm not giving you advice one way or t' other... uh uh, not me.
Old Mar 28, 2005 | 12:34 PM
mandm1200's Avatar
mandm1200
The threads and castlenut nut are there for a reason. I would not advise driving the car at all until it repaired. That would make as much sense as driving it with 4 stripped lug nuts, all that is needed is one to keep the wheel on.
Old Mar 28, 2005 | 01:32 PM
norvalwilhelm
If someone wants to go out and kill themselves then so be it but what about the innocent person, could be someone's wife, husband and child and the wheel comes off and in the resulting head on one could die. This is everyone's problem.
Be responsible and fix the car before risking everyone's life.
To rear spindle safety question
Old Mar 28, 2005 | 06:24 PM
turtlevette
With all due respect and you know i have the utmost respect for your knowledge, everything in life is a risk. People take calculated risks every day. I'd take my chances driving by or in this car with a responsible competent driver rather than all the soccer moms in the brand new mini vans and mammoth SUVs screaming at their kids and putting on their makeup.
If the bearing is pressed on, it is unlikely to come apart. In addition it would take several hundred pounds of force to shear that cotter pin. Normal driving around will not put these kinds of stresses on it. Its probable that this condition has existed for some time.
Lets see what he says about whether the shaft or nut is stripped and see if it is salvageable. I'd really like to see him get to his car show. If we all worried about everything that could happen we'd never take these things out of the garage.
Old Mar 28, 2005 | 06:47 PM
mandm1200's Avatar
mandm1200
'Everything in life is a risk' is just a general statement. There are ways to reduce risk so that it is minimal. You could tighten rod bolts and main caps finger tight and the engine will start and run. Why go out and spend money on tools to torque down nuts and bolts? Even if done properly there is still a risk of failure. The purpose is to reduce the risk and not take un-necessary chances.
Old Mar 28, 2005 | 06:52 PM
Scudd's Avatar
Scudd
How would you know the spindle is bad without looking at it?
