'74 is Backfiring
Any help would be greatly appreciated.
Borrow your wife's sewing measure tape and wrap it around the harmonic balancer to measure the circumference. Divide the measurement by 10 (360 degrees all the way around.. one tenth of 360 is 36). Take the number you get and measure off that distance clockwise from your existing balancer timing mark (as seen from the front of the engine). Place a mark there. That mark is 36 degrees. You can now use your standard timing light to set the engine up for 36 degrees total by aligning the new mark with the "0" point on the timing tab.
Aways set total timing with the hose pulled off the vacuum advance control unit. It doesn't matter if you plug it or not - the vacuum leak will no affect timing as long as the hose has been yanked off. The 36 total should occur when you rev the engine up until you do not get any more centrifugal advance out of it as observed with your timing light. This should ideally occur below 3000 rpm.
Yes, you can check your vacuum advance easily, too. First, hook up a vacuum hose to the vacuum advance unit and suck on it. It should hold a vacuum (no leak). Now, place a mark on your balancer halfway between your stock timing line and the new 36 degree mark. This mark is 18 degrees.
Now, keep in mind that a performance vacuum advance control unit will pull in about 16 degrees of additional advance when fully "sucked in." With that in mind, start the engine without the vacuum hooked up. Using your new timing lines as a reference, (or your original one if possible), note what your base initial timing is at idle. Chances are, the 18-degree mark will be pretty close to lining up to something on the tab: subtract or add the number of degrees that the 18-line is off the "0" mark to read the timing. Note this number. Now, attach the vacuum advance hose to a straight manifold vacuum source so the full advance slams in. This will change idle speed, so adjust your idle speed back down to the same speed as it was before. Now, see how much timing you have at idle: You can probably use the 36-degree mark to interpolate about how much vacuum advance you have coming in. If you're pulling more than 18 degrees of vacuum advance, replace the vacuum advance unit with a shorter curve unit.
For operating purposes you can use either ported or manifold vacuum for your vacuum advance - use whichever source produces best quality idle once you have the 36 total timing established. Depending on how much initial timing you end up with once you get the 36 total, the engine may idle best with either ported or manifold vacuum. Use the sources as a tuning aid in setting your car up for best idle and off-idle response.
PS - Once you're done with your wife's tape measure, wipe all the grease off of it and put it back where you found it. DO NOT tell her you used it on the car.
