1974 vette
1974 Corvette
RPO Description Quantity Cost
1YZ37 Base Corvette Sport Coupe 32028 6001.50
1YZ67 Base Corvette Convertible 5474 5765.50
n/a Custom Interior Trim 19959 154.00
A31 Power Windows 23940 86.00
A85 Custom Shoulder Belts (Std with Coupe) 618 41.00
C07 Auxiliary Hardtop for Convertible 2612 267.00
C08 Vinyl Covered Auxiliary Hardtop (Conv.) 367 329.00
C50 Rear Window Defroster 9322 43.00
C60 Air Conditioning 29397 467.00
FE7 Gymkhana Suspension 1905 7.00
n/a Optional Rear Axle Ratio - Positraction 1969 12.00
J50 Power Brakes 33306 49.00
LS4 Optional 270 HP, 454ci Engine 3494 250.00
L82 Optional 250 HP, 350ci Engine 6690 299.00
M21 4-Speed Manual Transmission (Close Ratio) 3494 0.00
M40 Turbo Hydra-Matic Automatic Transmission 25146 0.00
N37 Tilt-Telescopic Steering Column 27700 82.00
N40 Power Steering 35944 117.00
QRM White Stripe Steel Belted Tires, GR70x15 9140 32.00
QRZ White Letter Steel Belted Tires, GR70 x 15 24102 45.00
U05 Dual Horns 5258 4.00
U58 AM-FM Stereo Radio 19581 276.00
U69 AM-FM Radio 17374 173.00
UA1 Heavy Duty Battery (Std with LS4) 9169 15.00
UF1 Map Light (on rearview mirror) 16101 5.00
YF5 California Emission Test 0 20.00
Z07 Off road Suspension and Brake Package 47 400.00
Color Codes
Code Color Quantity
910 Classic White * No Numbers Given
914 Silver Mist
917 Corvette Gray
922 Corvette Medium Blue
948 Dark Green
956 Bright Yellow
968 Dark Brown
974 Medium Red
976 Mille Miglia Red
980 Corvette Orange
I checked on this website for some specifications. They did not include the number of vettes by color for the 1974 year.
http://www.alarid.com/history/specs/74.htm
For 1974 the code for yellow was #956 Bright Yellow.
For 1975 the code for yellow was #56 Bright Yellow and 2,883 cars were made.
Maybe someone has the fact book for the 1974 year for you.
kdf
Thanks.
