TPI surging (?) idle
Old Mar 28, 2005 | 10:31 PM
toyvet1's Avatar
toyvet1
Default TPI surging (?) idle
JUst started up the 383 over the weekend. Seems it doesn't want to hold a steady idle.If I adjust the AIC to idle at 800(its a 4 speed) it will idle fine then jump to 1050 for a short time then drop to 700 ect... Any idea where I should be looking. All sensors are new,no apparent vacum leaks, 7730 ecm
Old Mar 28, 2005 | 10:38 PM
jcswm's Avatar
jcswm
Ohm test your injectors.... they should all be exactly the same ohms
Old Mar 28, 2005 | 11:12 PM
toyvet1's Avatar
toyvet1
New injectors and the ohms all checked out good,,,,,,,
Old Mar 28, 2005 | 11:59 PM
carriljc's Avatar
carriljc
Default did you burn your own chip?
If you are, you can go here and make a copy of some other 730 bins to see if it cures your surging.
http://www.moates.net/fileman/index....ied%20Binaries
Old Mar 29, 2005 | 12:15 AM
vetteaddic's Avatar
vetteaddic
Have you turned the ignition key on and depress the accellerator fully and let off ,,try that
To TPI surging (?) idle
