Removing door panel
Old Mar 28, 2005 | 10:42 PM
copter's Avatar
copter
Default Removing door panel
I have to take off my pass side door panel on my 82CE.It has electric door locks and I'm not sure how to remove the operating toggle switch thing.It don't have any screws.Do I pry it off?
Old Mar 28, 2005 | 10:51 PM
zaphodbebullbrox's Avatar
zaphodbebullbrox
on my 1980 door panels with electric door lock, you can pop the toggle switch out the back of the door pannel via two metal clips, or pull the connector off the toggle switch.
Old Mar 28, 2005 | 10:56 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
It's easiest to just reach up behind the door panel as you take it off and unplug the connector. The switch is held on with spring clips and I think it's less risky(to do damage to the opening) to be able to depress the clips from behind rather than try to pop the switch loose from the front. At least that's my preferred method.
Mike
lars's Avatar
lars
copter -
You don't need to take the door lock switch off to remove the panel. Once the panel comes off, the switch stays on the panel and you can reach behind the panel to pull the wire harness off it.
Old Mar 28, 2005 | 11:12 PM
copter's Avatar
copter
Thank you.I was hoping that was the case.You guys are great!!
To Removing door panel
