TKO 600 vibration
Old Mar 28, 2005 | 11:23 PM
vetteaddic's Avatar
vetteaddic
Default TKO 600 vibration
Just got my car running again after dropping in a 427sb with the tko 600 5 speed, everything is running fine except for the vibration im getting around 90mph and the higher i go it gets worse,thats in 5th,I didn`t notice this before when i had the 4 speed,could it be the angle of my driveshaft not enough,need some advice from you guys,Im going to call keisler also,,,,,THANKS
Old Mar 29, 2005 | 12:23 AM
Schmucker's Avatar
Schmucker
Check to see if you get vibration associated with speed or RPM. Rev it a bit in neutral and see if it vibrates. See if you get the same vibration at 5000rpm in 1st as you do in the other gears, do you get the vibration with the clutch disengaged, etc?
Old Mar 29, 2005 | 12:44 AM
zwede's Avatar
zwede
Yeah, it is very possible that your u-joint angles are wrong. The TKO has to go way up in the tunnel to get decent angles. I actually cut a relief in the tunnel (under the console) to get it up further. I made an aluminum plate that bolts down and seals the hole. Even so the angles were not perfect but pretty close.
Old Mar 29, 2005 | 09:10 AM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
Marcus, you just hit a nerve associated with my Tremec TKO swap. In addition to the issues talked about in other threads I am also concerned about the drive angle. I have TKO positioned as far up as possible and actually touching the tunnel near the rear (just before the tail shaft). Kiesler and others advise that the angle is not that critical, but the profectionist in me worries otherwise. What angles before and after were you dealing with?
Bullshark
Old Mar 29, 2005 | 08:00 PM
WESCH's Avatar
WESCH
Hi
The M21 also had some drive shaft angle/misalignment. The main thing to watch is that the rear end angle is the same as the engine/tranny angle ( looked against a horizontal line ) . A mismatch doesn't matter so much, but if both this angles are different, the aft versus the front cardan ( flex joint ) work at different rates and twist the drive shaft and actually also moves the slip joke in and out every 1/2 turn of the drive shaft.
I can imagine this producing vibrations.
I must obmit, it is near to impossible to measure the rear end and tranny angles, so positioning the drive shaft in the same location it had before with the M21 should be fine ( I hope ).
Günther
Old Mar 29, 2005 | 08:03 PM
WESCH's Avatar
WESCH
Hi
I just remembered a thread about vibrations caused by CF DF clutches due to the assistance weights apparently sometimes not centering.
What clutch are you running ?
Günther
Old Mar 29, 2005 | 08:28 PM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Driveline angles are definitely a possibility.
Schmucker hit on it. You need to determine if it's the vehicle speed (and thus the driveshaft speed/trans output) or the engine speed (clutch/flywheel/trans input).
At the speed where you get the vibration, what happens in other gears? You said it happens in 5th. What if you shift into 4th at that same speed? Same vibration? What if you drive at that same engine rpm in 2nd, 3rd, or 4th? Any vibration?
Old Mar 29, 2005 | 08:41 PM
SteveG75's Avatar
SteveG75
Easy way to determine if it is driveline is to get up to speed and then just push the clutch in and coast. If you still have the vibration, it is driveline related.
I am currently trying to get my Tremec higher based on some measurements I did tonight with my old T-10. Of course, then I managed to strip the bolt hole in the tranny but that is a story for my other thread.
Old Mar 29, 2005 | 09:43 PM
WESCH's Avatar
WESCH
Hi
Yes and... no. If its the clutch , it will not show up this way.
Also was the flywheel resurfaced ? And if yes, was it balanced afterwards ? This are much bigger rotating masses as just a drive shaft.
Finding the cause of vibration is not always so obvious.
Good luck. Günther
Old Mar 29, 2005 | 09:49 PM
SteveG75's Avatar
SteveG75
Originally Posted by WESCH
Hi
Good luck. Günther
Absolutely true Gunther.
The clutch in and coast check will help eliminate the engine or flywheel/pressure plate as a source of vibrations since they are turning at idle speed. Obviously the clutch disc, transmission, and driveshaft will still be at road speed. After all, every little bit helps when trouble shooting.
Old Mar 29, 2005 | 10:11 PM
rihwoods's Avatar
rihwoods
This may help or not help:
http:www.tracyvette.com/vibrationdiagnosis.html
Old Mar 30, 2005 | 04:06 PM
vetteaddic's Avatar
vetteaddic
I do have a cf clutch ,but dont think this is the problem,I believe its a driveline vibration because I did push the clutch in and the vibration was still there,I think I put it in nuetral also going down the hiway,I dont feel it going thru the gears only when around 90 and up and gets worse,....also I did not install my center exhaust hanger and wonder if this would change the pitch angle some on the driveshaft,,,,,and Gunther are you talking about side to side or up and down angles.. THANKS AGIAN guys
Old Mar 30, 2005 | 04:28 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I had a vibration, could not figure it out for two years, ended up gbeing my rear wheel bearings. Maybe you did not notice it at 90 MPH because your car wouldn't go that fast before with the 4 speed
Old Mar 30, 2005 | 08:34 PM
norvalwilhelm's Avatar
norvalwilhelm
I had the same problem but mine started to vibrate at 60 lasted till 70 , went away and came back really bad at 90 and couldn't drive above that.
I ended up improving the drive line alignment both up and down and side to side.
I push the tailstock as high as possible, right up until it hits the tunnel and then when you let it settle on the mount it pulls away very little but enough.
I measured then angle with a protrator. I then measured the rearend and found I needed to raise the rearend so I shortened the spacer, Make the angle equal and opposite, the trail stock is down so the rearend must be up.
I also found the tailstock didn't point to the rearend, I made a special tool and re aligned the rearend left and right.
My pinion pointed towards the passengers front tire, that was wrong so I move the pinion more in align.
I have absolutely no vibration right up to 130 mph where I quit but not a whimper.
Old Mar 30, 2005 | 08:54 PM
Keisler Automotive's Avatar
Keisler Automotive
Default from Keisler
Dear Customer,
Please contact our tech department x3 to support the kit you purchased from us. We have been able to solve every vibration problem put forth thus far.
To TKO 600 vibration
