Pulling to one side
Old Mar 29, 2005 | 12:02 PM
more_cc's's Avatar
more_cc's
Default Pulling to one side
Our recently purchased 1980 C3 4sp corvette has just had new bearings all round and new u-joints. After this I felt a little more confident about giving it some gas and not breaking anything!
So here's the problem, under full acceleration the car pulls to the left, when I let off it seems to want to pull to the right.
I've noticed there's a lot of play in the ball joints and the front suspension generally looks in need of a rebuild but is there anything specific that could be contributing to this?
Thanks!
Old Mar 29, 2005 | 12:04 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
did they also replace the trailing arm bushings? I had a bad bushing and that's exactly the way it acted.
Old Mar 29, 2005 | 12:12 PM
isosceles's Avatar
isosceles
I had the guys at Van Steel fix mine. Never pulled like that again!
Old Mar 29, 2005 | 12:42 PM
more_cc's's Avatar
more_cc's
No they didn't replace the trailing arm bushings, is there anyway I could tell if that's the problem? If it is, how difficult is the job?
Old Mar 29, 2005 | 01:13 PM
kens 80's Avatar
kens 80
Sounds stupid, but check your motor mounts, I have had this problem on two of my friends vettes and the motor mounts were bad.
Old Mar 29, 2005 | 03:56 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
Might want to check your P/S control valve
Old Mar 29, 2005 | 04:38 PM
Tom454's Avatar
Tom454
If you had "bearings done all the way around".... they probably removed the trailing arms. Make sure they re-installed & properly tightened the aligment shims & through-bolt at the front of the trailing arms (where the bushing is).
Old Mar 29, 2005 | 05:58 PM
more_cc's's Avatar
more_cc's
How would I check it? What should I be looking for?
Old Mar 29, 2005 | 10:57 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
That sure sounds like the t-arm bushings to me. Might as well do the a-frame bushings as well as a front end rebuild as well. That 25 year old rubber doesn't owe you anything anymore.
Old Mar 30, 2005 | 11:53 AM
more_cc's's Avatar
more_cc's
Okay my mechanic said he did take the rear trailing arms off when he did the bearings and yes the bushings were a little worn but not worthy of being replaced.
So I've ruled that out, Big Fish you say it could be the T-Arm bushings, which are they? If I do a front end rebuild will the rebuild kit include the T Arm and A Arm bushings?
Old Mar 30, 2005 | 08:27 PM
Big Fish's Avatar
Big Fish
A front end kit would not have bushings for the T-arms (trailing arms)
To Pulling to one side
