What year TPI to use??
Old Mar 29, 2005 | 02:28 PM
madman's Avatar
madman
Default What year TPI to use??
I'm thinking about a TPI for my '79. What years are the best and easiest to use.
Old Mar 29, 2005 | 03:32 PM
PatsLs1vette's Avatar
PatsLs1vette
What r u looking to do with it,just a weekend cruiser? or big cam, head work, headers etc..Mass air setups will work with changes better without having to reprogram the prom every time.Speed density setups if your making cam changes and heads etc.. need the prom to be worked with .NIce part about speed density is the air filter can go right on the end of the throttle body and you dont have to worry about the ducting and mass air flow sensor.I use a maf setup from a 87 trans am.If your just going to bolt it on and use your stock cam then speed density will probably work better for you.Others will chime in with there ideas also im sure,this is my oppinion.
Old Mar 29, 2005 | 03:33 PM
mrtroutjedi's Avatar
mrtroutjedi
well i bought one out of an 85 corvette but..............I have yet to go out to the garage and install it but ill get around to it sooner or later if only could get someone over to help me?
Old Mar 29, 2005 | 03:59 PM
thebruce's Avatar
thebruce
Here's a pretty good FAQ on the different types of setups, with a discussion of MAF and Speed Density.
http://www.classictrucksweb.com/tech/0404cl_tpi/#
I haven't installed mine yet, but I converted a 1985 harness to work with a '86-89 computer. I'm going to copy Pat's MAF and C5 air bridge setup.
The one thing I am going to do differently is use a Prominator flash-based interface instead of a chip, that way I can mess around with tunig without having to burn my own chips. Of course, I don't have any of the system installed yet, so we'll see what actually happens once I start.
Old Mar 29, 2005 | 08:53 PM
markdtn's Avatar
markdtn
See
http://forums.corvetteforum.com/show...&highlight=TPI
It has some basic year-by-year info.
Old Mar 29, 2005 | 10:49 PM
madman's Avatar
madman
Default More engine info.
The engine is a rebuilt L-82, Edlebrock RPM heads, new COMP cam (6000 rpm), headers (1 3/4"). The car will be a weekend driver.
I like MAF setups a little better since they always tune themselves, but I had an '86 Lincoln with a speed density system that worked fine.
Old Mar 30, 2005 | 02:11 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
There are several good books on TPI swaps/modifications. I'd recommend checking them out.
Old Mar 30, 2005 | 03:36 AM
i885744's Avatar
i885744
definately go with a mass air setup if you plan on doing cam changes. A 87 trans am or camaro setup will be your best bet. It has no VATS(anti theft) to worry about, and its a mass air setup. You can get a 3 wire hookup wiring harness from painless wiring for dirt cheap, i strongly reccomend going with them, it will save you tons of time and headache. I did the swap on a 78 chevy, feel free to pm with any questions, there are several tpi setups on this forum as well.
Old Mar 30, 2005 | 11:18 AM
corvettecris's Avatar
corvettecris
Old Mar 30, 2005 | 11:24 AM
Joebio's Avatar
Joebio
If you are diong this swap do you need to change out your distributor as well?
Old Mar 30, 2005 | 11:28 AM
PatsLs1vette
yes you cant use your stock tach drive or regular hei.ITs computer controled.
To What year TPI to use??
