Greaseless U-Joints
Old Mar 29, 2005 | 08:38 PM
swtato's Avatar
swtato
St. Jude Donor '05
Default Greaseless U-Joints
Can anybody tell me where to buy Greaseless U-Joints for my rear half axles online?
Old Mar 29, 2005 | 08:55 PM
b71vette's Avatar
b71vette
Default VanSteel sells Spicer
which are suppose to be the best.
Old Mar 29, 2005 | 10:20 PM
Steve's74's Avatar
Steve's74
VanSteel. Top quality.
Old Mar 29, 2005 | 11:00 PM
desi's Avatar
desi
I just bought the Neapco Brute Force from Advanced Auto Parts. They are $15 a piece. Quality looks good, but I have not installed them yet.
Old Mar 29, 2005 | 11:40 PM
swtato's Avatar
swtato
St. Jude Donor '05
I wondered about those also? What would the difference be between those and Spicer? Both are talked about on 4x4 websites. They cost 1/2 as much.
My other concern about Greaseless is that I read they are not good for the street since they would have to be taken apart to lubricate often. Is this true? I wanted to use them so I don't have grease sling out from the other joints. Van Steel actually recommended using the greaseless.
Any advise would be appreciated
Old Mar 30, 2005 | 12:24 AM
b71vette's Avatar
b71vette
Default Greaseless are stronger
can take more torque since the shafts are solid. Grease type has hollow core shafts to allow grease to go thru.
Old Mar 30, 2005 | 07:49 AM
GTR1999's Avatar
GTR1999
I think I have 1 or 2 sets left of the Spicer solids.PM me if you're interested. I also have 1 flange plate too so you don't bend the flange working on them. Hopefully they're not already bent.
Gary
Old Mar 30, 2005 | 05:23 PM
fast idle's Avatar
fast idle
i have the greaseless ones and they were recommended by the dealer. they do not need to be re-lubed as i have been told
Old Mar 30, 2005 | 08:26 PM
desi's Avatar
desi
All newer cars are non greaseable...and no need to re-grease them either.
Old Mar 31, 2005 | 07:36 PM
joe73vette's Avatar
joe73vette
NAPA sells the greaseless ones, too. Joe
Old Mar 31, 2005 | 08:05 PM
BUGGSY1970's Avatar
BUGGSY1970
Greasless ones are meant to last about 10 years if you are worried about them after that get the ones with grease fittings. Greasless are definitely stronger and take more abuse. Which way to go is up to you.
Old Mar 31, 2005 | 10:22 PM
swtato's Avatar
swtato
St. Jude Donor '05
So would greaseless be ok for every day driving?
Old Mar 31, 2005 | 10:36 PM
stingry's Avatar
stingry
St. Jude Donor '05-'06
I would say yes.
I have the greasless ones in mine. They technically have grease in them, you just add more. Sort of like a steering box really. When they U-joint needs grease it is just cehaper to replace it.
I like SPICER. SPICER Senior (or his dad) was the man I believe who invented U-joints so I figure SPICER knows somehting about making them.
To Greaseless U-Joints
