79 Radio Install Question
Old Mar 30, 2005 | 09:15 PM
wwaag's Avatar
wwaag
Default 79 Radio Install Question
I'm trying to install an aftermarket radio into my 79. Purchased the wiring harness adapter from Eckler's. The new radio calls for a couple of yellow wires to be hooked up a constant voltage source (battery). I presume that they should hook up to this yellow wire that came with part of the kit from Ecklers.
Question--where does this plug in?
It also calls for a chassis ground. Any suggestions?
Thanks in advance.
wwaag
Old Mar 31, 2005 | 02:19 PM
wwaag's Avatar
wwaag
Just figured it out. It plugs directly into the fuse block giving you a direct circuit to the battery. That way, you're not using power from any other circuits.
