Rebuilding a Short Block
Old Apr 1, 2005 | 02:34 PM
BIGJIM13's Avatar
BIGJIM13
Default Rebuilding a Short Block
HI
thinking about rebuilding my 350 all the way, anyone know of any good prices on a Master rebuild kit and any online how to references?
Old Apr 1, 2005 | 03:16 PM
markdtn's Avatar
markdtn
PAW (used to have multi-page advertisement in Car Craft, Hot rod Etc.), Northern Auto Warehouse, Jegs,and Summitt have good complete kits.
Old Apr 1, 2005 | 03:27 PM
marshrat99's Avatar
marshrat99
JC Whitney has a couple of videos you might be interested in. One is on basic rebuild of a SBC. The second one is almost a Part II of the first and is on hi-performance considerations when building a SBC. Both videos assume you have other reference materials available to you for spec's for your particular application.
Have a look at Scroggins-Dickey for rotating assemblies and such.
Old Apr 1, 2005 | 03:33 PM
Fevre's Avatar
Fevre
Eagel offers a 383 balanced rotating assembly for under $1,000. You just need to clearence the block a little bit in a couple of lower cyl walls and oil pan rail plus either clearence the rod bolts or buy a small base circle cam. All in all it will very close in price to buying a rebuild kit and having it balanced.
Also check out www.ohiocrank.com, they some cheap stroker kits too.
Old Apr 1, 2005 | 03:35 PM
greyghost79's Avatar
greyghost79
BIGJIM13's Avatar
BIGJIM13
Thanks very much!!
Old Apr 1, 2005 | 04:26 PM
GTR1999's Avatar
GTR1999
I'm looking at the kits at Northern now. You can upgrade to name brand parts and still get a decent deal. You have to start with their $159.99 masterkit which has a lot of the "white box" builder parts in it. I'm thinking of going with .020 over speed pro hyper pistons (+$20) Speed Pro molt plasma file fit rings(+86) clevite 77 P brg's (+$6) keeping the Melling 55 pump in the kit, adding a steel pump shaft($7). It comes with a mellow stock cam but you can upgrade to several name brand cams. Probably run about $300 for what I want, not bad. Machining cost will be around $700-800 so I hope to get what I want done for under $1,500. I already have new WP Torquers that I ported and polished ready to go on along with a Comp 260H cam. Should be a nice street motor for my setup.
Gary
To Rebuilding a Short Block
