Dorr Panel Cracks
Thanks.
Thanks.
I'd replace the panel rather than using the patches they sell. The patches look bubba and if you replace the entire door panel and keep it supple with whatever you like such as Armorall or Leatherique it should last. The door panels in my 68 (which I have owned since 1972) still have no cracks and all I use is Armoral. Vaseline petroleum jelly also works very vell on vinyl as it keeps it soft especially if you heat it and/or park it in the sun. Try it, what have you got to lose. I periodically lightly smear vaseline on my vinyl dashboard and park it in the sun and then remove the residue. The vinyl is nice and soft and no cracks whatsover.
Kurt
I have them on both panels and they don't look bad at all. Perfect for a driver.
I have them on both panels and they don't look bad at all. Perfect for a driver.The Best of Corvette for Corvette Enthusiasts
James
Now, Thanks to Carl, I'm thinking I could get a piece of impregnated fiberglass mat behind the crack to bond the two sides together since it will initially be more flexible than a piece of vinyl and give it a little extra reinforcement once cured. I think I would try and keep all of the resin on the backside of the vinyl and clean off any that got on the good side. Then finish off the repair with gap filler and dye.
Carl, even if you had to use the resin on the good side couldn't you cover it with gap filler which would most likely take the dye better than the fiberglass?
I was also thinking of trying to make a "vinyl pattern mold" that I could imprint the gap filler with as it dried. Any ideas on what I could use to make the pattern mold? I was thinking maybe tool dip rubber.
