Dorr Panel Cracks
Old Apr 4, 2005 | 08:40 PM
Maymyvetteliveforevr's Avatar
Carl, loved your pictures...but had to laugh. My wife basically rolled her eyes because there's obviously other guys who have car parts all over the house too! Let your wife know that she sympathizes.
carl a's Avatar
carl a
finished dash pad------------
Old Apr 4, 2005 | 08:42 PM
I've purchased the leather dye spray can from Ecklers but am curious...are you supposed to use a primer coat before using the dye spray. If so, is there any place I can pick this up locally. Does it matter if it's metal, leather, plastic....etc.?
Old Apr 4, 2005 | 08:49 PM
carl a's Avatar
carl a
i never primed... now you might notice,that the part you dye comes out like a semi gloss finish,,,,,them with the very same paint can the next piece comes out flat,,,a lot of guys were saying thats cuz the cans of paint are from different lots....but not when this happens from the same can!!! the reason it does this is simple,,,different materials that you dye will take differently to the dye,,,some will allow a small shine others wont,,,depends on the material,,,so to solve this problem what i did was simple,,,i clear coated the parts after the dye dried and they all matched-tip of the day!!
Old Apr 4, 2005 | 08:51 PM
carl a's Avatar
carl a
heck i was trying to talk her into letting me put the 73 in the frt room over the winter and we could play ''drive inn'' and throw out the sofa!!!
Old Apr 5, 2005 | 12:16 AM
gdh's Avatar
gdh
great idea on the dash pad, I will do the same with mine.
Old Apr 5, 2005 | 05:06 PM
joe73vette's Avatar
joe73vette
Here are pictures, they are obvious if you are looking for them, but to the casual observer they look like they belong there. Black helps, too, I guess. Joe
Old Apr 5, 2005 | 08:25 PM
I think the fact that it's black sure helps joe, unfortunately i have silver therefore i think it will be a bit more obvious. Carl..... or anyone for that matter, before dying the interior parts, how do you clean, or should I say prepare the vinyl, and or leather?
Old Apr 5, 2005 | 10:03 PM
carl a's Avatar
carl a
i just cleaned them with soap and water and its worked for me
Old Apr 6, 2005 | 11:58 AM
I like soap and water, Inexpensive. Therfore soap and water, no primer and apply dye. Thanks carl a.
Old Apr 6, 2005 | 12:21 PM
GATOR454's Avatar
GATOR454
I use Ivory bar soap to clean vinyl and leather before dying, it only contains soap (no oils, moisterizers, etc.).
Old Apr 6, 2005 | 05:37 PM
2 points for soap and water. Going going .......................................
