BB with TKO installed today...Pics
Old Apr 2, 2005 | 12:13 AM
Engraver's Avatar
Engraver
Default BB with TKO installed today...Pics
Installed the motor and TKO as a unit today. It was scary holding that big motor over the car like that, but all went well.
Small things I should have done different
1... The motor mounts. I had them bolted to the motor to start with, but no way could the frame portion they sit on get lined up. I crawled under the car and removed them from the motor and installed them on the frame.
2... The crank on the hoist hanger to shift the weight. I should have had that handle for it pointing to the front. With it pointing to the rear when the motor was close to home I couldn't crank the handle because it was hitting against the firewall.
3... Discovered there is no way these tall valve covers are going to work. The passenger side one hits against the firewall. I'll have to find some shorter ones.
Anyway it is in!!!! and I didn't break a thing
Old Apr 2, 2005 | 12:17 AM
Brettmc's Avatar
Brettmc
Schweet!
Brett
Old Apr 2, 2005 | 12:39 AM
olouieo's Avatar
olouieo
WoW
Old Apr 2, 2005 | 01:13 AM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Cool, I noticed it has AFR heads, what is the motor build? I went through the same battle with my 69. I found the only valve covers that would fit over my stud girdle and clear everything was the GM bowtie racing valve covers.
Old Apr 2, 2005 | 01:53 AM
WESCH's Avatar
WESCH
Hi
So, you did not cut the crossmember , did you ?
Günther
Old Apr 2, 2005 | 05:30 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Great job. Nice pictures. You're right about all that weight hanging over the front end. Scary.
Old Apr 2, 2005 | 07:42 AM
LIQUIDDRAGON's Avatar
LIQUIDDRAGON
nice pictures and thank you for the tip with the motor mounts sense i will be pulling my engine again here in a week and a half so i can install my new wiring harness and do some engine compartment cleaning and repainting. it was a pain in the ___ to get the mounts lined up when i installed my engine and would have never thought to have them mounted together and on the frame
Old Apr 2, 2005 | 07:51 AM
GDaina's Avatar
GDaina
Use the stock ones, even if you have full roller rockers...I'm usung Harlan Sharp Al. rockers, stock covers, doubled up on the gaskets, trimmed the tips of the drippers...1/8", and had to cut a small 45 off the corner of two rockers to clear the valve cover bolt relief....works great, no leaks.
Old Apr 2, 2005 | 11:01 AM
LemansBlue68's Avatar
LemansBlue68
Man, that looks like a sweet setup and a sweet '69!! Let us know how it runs.
What setup are you running for your motor? Give us some details, please.
Old Apr 2, 2005 | 11:32 AM
carbster09's Avatar
carbster09
Default Great stuff!
That looks great. I love the engine. what's the spec?
carbster
Old Apr 2, 2005 | 02:22 PM
Engraver's Avatar
Engraver
Thanks... Sure glad it is in. I feel like things are moving now.
Here are the specs:
BB 427, four bolt
Hydraulic roller Crane cam grind number: HR-288-2S-12 IG
Cam Timing: @.050
Lift: Opens Closes Max Lift Duration
Intake 6.0 BTDC 40.0 ABDC 107 226 °
Exhaust 54.0 BBDC 0.0 ATDC 117 234 °
Valve lift: .587 intake, .610 exhaust
Crane gold roller rockers
Standard TRW forged piston
AFR 305CC heads with 119cc combustion chamber
(Should be around 10:1 compression)
Edelbrock dual-quad intake with two Edelbrock Performer 600cfm carbs
Keisler 5 speed 600TKO
3.05 rear for now. I'll try it with this rear but I have an idea I'll be changing
Hooker headers/sidepipes
_________
69 N.O.X. RATT and GDaina, Thanks for the info about the valve covers. I'll start shopping Monday.
Old Apr 2, 2005 | 02:34 PM
Engraver's Avatar
Engraver
Originally Posted by WESCH
Hi
Günther
Nope... didn't cut it.
Old Apr 2, 2005 | 02:41 PM
Bob Turner's Avatar
Bob Turner
Congrats on the successful install!
That cherry picker looks VERY FAMILIAR!!
When do you think you will fire her up??
Bob
Old Apr 2, 2005 | 02:48 PM
WESCH's Avatar
WESCH
Hi
3.05 rear for now.
May be OK for the TKO 500 , but for the TKO 600 you will sooner or later want to change to 3.70.
Günther
73 LS-4's Avatar
73 LS-4
I have the same valve covers and rocker arms, I eventually got them to fit but it took quite a bit of work especially with my power brakes, and I hated tearing up the new expensive valve covers but they do look nice. Let me know what you end up going with on the valve covers with those rocker arms becouse I want to switch to something shorter since changing the drivers side valve cover is now a nightmare.
Pat Kunz
Old Apr 2, 2005 | 04:56 PM
Engraver's Avatar
Engraver
Pat Kunz
The drivers side valvecover fits since I don't have power brakes. The passenger side is tough to get on with the vacuum deal there. I loosened and pushed it out of the way but even then the valve cover is against the hearter core box and won't go on all the way. Is yours riding against the heater core box there?
Old Apr 2, 2005 | 05:24 PM
73 LS-4's Avatar
73 LS-4
Mines a 73 so I don't have the vacuum controls for the wiper door there but there was some clearancing issues with the heater core box, I had to cut part of it and reseal it.
Pat Kunz
To BB with TKO installed today...Pics
Old Apr 2, 2005 | 05:31 PM
Engraver's Avatar
Engraver
Okay, Thanks Pat. I'll go back and take another look at what I would have to take off the heater core box to make it fit.
Old Apr 2, 2005 | 06:16 PM
matchframe's Avatar
matchframe
Congratulations!!!
I can't wait until I am at that stage of my project!!
www.bigdogvettes.com
Old Apr 2, 2005 | 06:58 PM
Engraver's Avatar
Engraver
I now realize I forgot to install the insulation in the tunnel. I bought that preformed silver tunnel insulation and had it laying right here, but I got in a hurry to get the motor in and forgot about it. Am I going to miss it? Does it make the cockpit that much cooler?
