balancing a 400
Old Apr 2, 2005 | 01:41 PM
79VetteMike's Avatar
79VetteMike
Default balancing a 400
So my parts got dropped off to get balanced. I'm letting a friend build the short block, so he dropped them off this morning. The crank is an intenally balanced Scat, the rods are 6" Eagle lightweigth SIR, and the pistons are KB hypereutectics. The cylinders are already honed for these pistons and rings. Well the shop looks at the parts and says they won't intenally balance. He says my pistons are too heavy. Anyone have a 400 interntally balanced?
Old Apr 2, 2005 | 02:53 PM
mandm1200's Avatar
mandm1200
Interesting?
Perhaps one of the more knowledgeable, professional engine builders will chime in and explain how to pick pistons (weight) for a certain crank.
Old Apr 2, 2005 | 02:55 PM
79VetteMike
I've looked at some othe manufacturers and their forged pistons seem to be heavier than my KB's, so I'm wondering if the guy just didn't want to do it or he doesn't know what he's talking about. The KB's are 430 grams and the pins are 145 grams. 4.165" bore.
Old Apr 2, 2005 | 03:09 PM
mandm1200's Avatar
mandm1200
I have no idea how they balance things other than they weigh pistons and rods to get them relatively the same weight. I purchased a 383 externally balanced stoker kit, with flexplate and damper, from a local machine shop/engine builder who balanced it. I thought the fee of $180 was high for balancing but I knew I could not do it.
Old Apr 2, 2005 | 03:17 PM
VETDRMS's Avatar
VETDRMS
I have the Scat 9000 series crank in my 406 with Scat 6.0" H-beam rods and SRP flat top pistons. The rods weigh 650 grams, the pistons weigh 424 grams. It was internally balanced with no Mallory metal required.
Old Apr 2, 2005 | 03:58 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I am not 100 % sure about this but my instincts tell me the guy is an idiot, take it to another shop
Old Apr 2, 2005 | 05:03 PM
79VetteMike
Does that include the pins? Thanks for your posts, you guys.
Old Apr 2, 2005 | 06:15 PM
VETDRMS's Avatar
VETDRMS
No, I think the pins are 110 grams.
Old Apr 2, 2005 | 06:30 PM
LFZ's Avatar
LFZ
Mike, I'm running an Eagle crank, same rods, and KB pistons...in my 383...all internally balanced and no mallory metal added to the crank. Sounds like this guys is giving you a bunch of bs. strange.
Old Apr 2, 2005 | 08:08 PM
79VetteMike
Thanks for the input guys. I thought the same things you guys are saying.
Old Apr 2, 2005 | 08:25 PM
Sharky Guam's Avatar
Sharky Guam
Yes, if all the pistons, rods and pins weigh the same, internal balancing is no problem. But if they have deviations, some extra work is needed. If you bought a crank that is already balanced, then the hard work is already done. So I am not sure what he is talking about. I suppose that he really does not know how to perform the work. Balanced cranks only require working with the pistons, rod, pins, and rings. It is not that complicated.
Old Apr 2, 2005 | 10:49 PM
WayneLBurnham's Avatar
WayneLBurnham
Default Not only is my 413 Internally balanced he got it to under
a half gram....gross bobweight was something like 1875g.....
...so much so he advised to not use a balancer at all (just a center hub) - which I didn't, but after some other major screw ups will be adding one shortly.
Mine did require some Mallory metal, but not much - on two weights I believe.
I have a crank from Eagle (I think the 4340 one...) and their H Beam rods with some Diamond custom nitrous designed ones. I also have the AARP L19 fasteners throughout and splayed 4-bolts (all studs where possible.)
Several agreed with the no balancer and I had heard of it before, but these are drag folks who think 10 run hours between rebuilds is amazing, so I won't be staying with that ssetup and will add a neutral balance FlowDampr or TCI Rattler.
(This genius also thought a bronze gear was a good idea on a cam that did not call for it - Comp Cams didn't agree and neither did the engine less than 2K miles later....)
To balancing a 400
