78 interior brake light question
Old Apr 3, 2005 | 02:55 PM
78vettman's Avatar
78vettman
Default 78 interior brake light question
When I got my car 15 months ago, I had to replace the master cylinder. The brakes have been fine since then. About 3 weeks ago, I noticed that my brakes were very spongy (I could put it almost to the floor before I would stop). The other day, i noticed that everytime I am slowing down, I hit the brake pedal and the interior light on the dash comes on. After I stop, I can pump the brakes a few times and the light goes out. Can you guys give me some suggestions?
Old Apr 3, 2005 | 02:57 PM
brooksman9's Avatar
brooksman9
St. Jude Contributor
Maybe a leaking wheel cylinder? Look and see if there is any brake fluid on the inside of any of the tires.
Old Apr 3, 2005 | 03:06 PM
Retro78's Avatar
Retro78
Why are you driving with a spongy brakes to begin with! The light indicates that either the front or rear brakes have failed/loosing pressure. Could be many things... broken line, defective master, leaking wheel cylinder, air in the system. Please,, fix it where it sits or tow to a garage. The light will come one when either the emerg brake is on, or you have low pressure/no pressure in either front or rear systems.
To 78 interior brake light question
