383 Rpm
Old Apr 3, 2005 | 09:25 PM
Witz's Avatar
Witz
Default 383 Rpm
I would be curious to hear what RPM you are running your 383's to.
I just pulled my motor after ten years of excellent service - actually nothing is wrong with it, but I'm installing a TKO 600 and didn't want to wrestle with the Rubik's Cube install, since my crossmember is not removable.
I have a 355 putting out 407hp at the flywheel. The motor was extremely well built by a local engine builder and I consistenly wind it up to 7000 RPM. I just brought the motor back to the same guy, 10 years later, and I'm thinking about taking it up to a 383. I'll miss the high RPMs, though. Anyone running their 383 to 6500 RPM?
Old Apr 3, 2005 | 09:36 PM
Ryan77's Avatar
Ryan77
Check out this thread:
http://forums.corvetteforum.com/show....php?t=1049641
Old Apr 3, 2005 | 10:29 PM
LFZ's Avatar
LFZ
i shift gears at 6500 rpm in my 383 all the time..i'm also running a Victor Jr. intake...it likes to rev fast, and pull hard past 6000rpm.
Old Apr 3, 2005 | 10:36 PM
gkull's Avatar
gkull
If your smart for the same cost you can build a 3.875 X 4.030 = 395.7 ci. Let your cam and intake determine your Max rpm. 7500 for a 383 is very easy and the 396 ci 7000 without any problems.
Old Apr 4, 2005 | 09:39 PM
C3 Stroker's Avatar
C3 Stroker
As stated above, your cam along with valve springs & induction will determine best rpm. Mine runs best when shifted @ 6500 rpm .....(375 HP at rear wheels).
To 383 Rpm
