Car bucks at WOT
Old Apr 4, 2005 | 10:37 AM
crazydalys's Avatar
crazydalys
Default Car bucks at WOT
When I driving my car if I floor it, the car will start to take off nice, then it will just cut out, then go, cut out, go, cut out, until I let my foot off the gas. What would be the cause of this? I have a stock '76 L-82 with a quadrajet.
Old Apr 4, 2005 | 10:39 AM
Stewart's74's Avatar
Stewart's74
Maybe you should check to see if your secondaries are opening properly. Mine had the same problem....easy fix.
Old Apr 4, 2005 | 10:50 AM
Les's Avatar
Les
It sounds like your secondaries are opening & closing under WOT. Many, many years ago I had this problem w/ my Q-jet right before I shelved it for a Holley. If you look at an exploded view I hope this will make sense. There's a small piston that's held in place by a thin hook-like wire. If I remember right this plays a part in secondary function. I found later that the shop that did the custom mods on my carb had left out the wire piece & that appeared to be my problem. Maybe Lars can chime in to clarify this. If you're lucky it may just be that you need to adjust the spring tension that controls the opening rate- that wasn't the case for me. Good luck.
Old Apr 4, 2005 | 10:53 AM
pws69's Avatar
pws69
Dirty fuel filter??
Old Apr 4, 2005 | 11:21 AM
crazydalys's Avatar
crazydalys
Originally Posted by pws69
Dirty fuel filter??
I just replaced the fuel filter, it idles better, but this problem persists. Maybe it's that spring?
Old Apr 4, 2005 | 11:54 AM
Stewart's74
Its called the Secondary Wind Up Spring.
Old Apr 4, 2005 | 12:00 PM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
Do you have the little fuel filter built in to the qjet, or an aftermarket in-line filter? This is exactly what my 68 truck did with a dirty fuel filter. Unless your distributer or something is not giving spark at WOT. I dunno.
Old Apr 4, 2005 | 12:23 PM
GTR1999's Avatar
GTR1999
Also check to see if you still have the "S" hoses to the fuel pump or just fuel line. I had this happen once with regular fuel line and it kinked and starved the carb at WOT.
Gary
crazydalys's Avatar
crazydalys
I have the little one built in to the quadrajet.
Old Apr 4, 2005 | 12:26 PM
crazydalys's Avatar
crazydalys
Default secondary windup spring
I'll have to try adjusting the secondary wind up spring. I see from previous posts it's on the passenger side of the carb. Does anyone have a picture of it's location they could post?
Old Apr 4, 2005 | 12:28 PM
crazydalys's Avatar
crazydalys
Gary
I'll have to check that. Thanks.
Old Apr 4, 2005 | 12:32 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Gary
I had this same problem once it it caused me to run the fuel bowls empty at WOT, then it would be fine under regular driving.
Old Apr 4, 2005 | 01:01 PM
PRNDL's Avatar
PRNDL
you should learn how to do this anyway, although I am a little skeptical that this is your problem. Does sound like fuel delivery to me.
There have been pics posted for this spring adjustment, but sorry I don't know where the pics are! It is real easy with a pic, but might be hard to figure out otherwise. You have to loosen an allenhead screw from underneath and then at the same time turn the adjustment screw from above.
Old Apr 4, 2005 | 01:55 PM
81 Vette's Avatar
81 Vette
St. Jude Donor '05
First C3 General Poster!
I had a problem like that in the Cutlass on its first engine, and it wasnt the carb at all, it was the distributor getting grounded to the engine and the spark wasnt generating properly. Check that out if youre carb turns out to be fine.
Old Apr 4, 2005 | 02:29 PM
lars's Avatar
lars
Sounds like fuel starvation at WOT - you're going lean. Causes include:
1. Low float level
2. Dirty filter
3. Kinked rubber fuel line either back at the tank or at the forward frame rail
4. More than 1 fuel filter installed (in-line filter somewhere in the system in addition to the in-carb filter)
5. Dirty tank pick-up sock
6. Poor fuel pressure (bad fuel pump)
7. Incorrect secondary metering rods (too fat)
8. Incorrect secondary airvalve spring windup (should be at 3/4 turn) - loose spring will cause lean secondary operation
Lars
Old Apr 4, 2005 | 03:01 PM
crazydalys's Avatar
crazydalys
1. Low float level
2. Dirty filter
Lars
Wow, well I know it's not 2 or 4. Sometimes it'll be running fine, then I'll fill up the gas tank and the symptons will start again.
Old Apr 4, 2005 | 03:29 PM
mvftw's Avatar
mvftw
Usually bogging down under a load is spark related, not fuel... Do a major tune-up. Are you using platinum plugs, if so, that's probably it...
Old Apr 4, 2005 | 03:52 PM
crazydalys's Avatar
crazydalys
Are the secondaries related to the choke? Sometimes it helps if I adjust the lean-rich mixture on the choke.
To Car bucks at WOT
