sputters/pops when decelerating
Old Apr 4, 2005 | 10:05 PM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
Default sputters/pops when decelerating
Im trying to figure out what my 76 is doing, really trying to figure out how to describe it....
Lets say I'm going about 55 mph, then let off the gas (4 spd manual) it "sputters" and sometimes "pops" out of the exhaust pipes. The pops and sputtering are louder if engine RPM is higher. Is this a timing/carb issue?
Old Apr 4, 2005 | 11:23 PM
EVIL_GRIM's Avatar
EVIL_GRIM
cold air getting into the exhuast?
Old Apr 4, 2005 | 11:28 PM
JoeRags's Avatar
JoeRags
my 70 did the same, was told that it was maybe running too rich. Leftover gas makes it into the headers and ignites there causing the pop and sputter. I put a smaller carb on and it went away.
Joe
Old Apr 5, 2005 | 12:00 AM
rihwoods's Avatar
rihwoods
Wait till it starts "farting" when you turn it off.You here a loud "poooof ". Heh.
Old Apr 5, 2005 | 12:06 AM
gdh's Avatar
gdh
installing an h or x-pipe will help fix this as well.
Old Apr 5, 2005 | 12:07 AM
Sharky Guam's Avatar
Sharky Guam
Recheck jetting and timing specs....air fuel mixture is fat coming out of the cylinders indicating incomplete combustion........
Old Apr 5, 2005 | 08:38 AM
ruby76's Avatar
ruby76
Good info. I don't think cold air is getting in, as I had to remove exhaust a little while ago and when I put it back on I made sure all bolts etc were tight. I'll check the carb, Im not sure that it is "right on" yet anyway. I need to get a vacuum gauge.
It currently has a square bore 750 CFM Holley that the previous owner put on. He also gave me a qjet. Perhaps the Holley is just too big?
Old Apr 5, 2005 | 09:14 AM
stingr69's Avatar
stingr69
Do you have a smog pump? A bad diverter valve will cause that. The properly functioning diverter valve diverts the air away under conditions of high manifold vacuum such as backing off the gas to shift gears etc. Basicaly the pump would be putting air into the exhaust all the time causing the noise if the valve is bad.
The other thing that comes to mind is leaking headers where the gasket to the head is installed. You need a good seal to prevent air from being drawn in. This will also cause afterfiring like you describe.
-Mark.
Old Apr 5, 2005 | 09:17 AM
Brettmc's Avatar
Brettmc
I experienced this when I was tuning my carb with my O2 sensor. It always happened when I had too lean of an a/f mixture. Try richening up the idle mixture screws 1/8 to 1/4 turns.
Brett
Old Apr 5, 2005 | 10:40 AM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Check the carb. You can make a car do this by opening the butterflys and reducing the amount of fuel coming through the idle circuit. So you're basically idling off the mains instead of the idle circuit. That's one possible cause.
Old Apr 5, 2005 | 01:59 PM
The Dude's Avatar
The Dude
Exhaust leak and/or part- or full-throttle mixture too rich.
Old Apr 5, 2005 | 02:20 PM
68vetteracer's Avatar
68vetteracer
Could be that the spark plugs are gapped incorrectly. My 69 had a similar problem and when i regapped the plugs it went away.
Old Apr 5, 2005 | 04:08 PM
lars's Avatar
lars
No, the carb is not too big. 750 is just right... This will not cause your problem..
Brett
That's exactly right: If the mixture is lean, it will pop in the exhaust on deceleration.
Suggest you do a couple of things:
First, check the list number on your Holley and see what jet sizes are supposed to be installed: Many of these carbs have had some "creative" jetting done to them, and many people go too lean on their setups. If you don't have the jetting specs, let me know and I'll give you the jetting for your list number.
If the carb has not been jetted lean, try running a jet size 2 sizes bigger than the stock jet on the primary side and see how the car responds to this. If it cures the problem and provides you better throttle response and power, jet the secondary side 7 to 8 jet sizes bigger than the primary side. This will give you a very nice setup.
You can also do as Brett suggested and richen up your idle mixture screws about 1/4 turn and see how it responds - this may give it enough to reduce the problem on deceleration.
Old Apr 5, 2005 | 04:21 PM
BB wowbagger's Avatar
BB wowbagger
Should this be done to a carb with PWs installed on both sides or just on the primaryside?
Old Apr 5, 2005 | 04:35 PM
ruby76's Avatar
ruby76
I'll try to get the mixture a little richer next time I get it out of the garage. Supposed to rain the next couple of days here.
The Carb is Holley 0-80508S, the manual says primary jets are 72, secondary jets/plate is 21-plate = 75 jet and a 65 power valve. I assume the jet size is printed/marked on the jets when I have a look? I don't have a vacuum guage and have no clue what cam etc is in the engine. I'll see if the idle mixture makes a difference first.
Someone earlier mentioned smog stuff, thanks for the suggestion, I guess I should have mentioned, there is absolutely no emissions stuff on the car.
Thanks guys!
Old Apr 5, 2005 | 04:37 PM
Pete76Shark's Avatar
Pete76Shark
I had the same thing on my 76 awhile ago and found the carb was running to lean.
LARS is always right on the money so listen to him.
I fixed mine by adjusting the power piston (stock Q-jet carb) just like Lars said to in one of his white papers. The power pistion was making it to lean when I came off the throttle and I would here small pops in the exhaust. I adjusted the piston to go a little richer (1/4 turn) and this resolved the problem.
Of course I know exactly how my Q-jet is setup to begin with and that makes it easy for me to tune it.
Old Apr 5, 2005 | 04:47 PM
BB wowbagger
Couldnt a leak between the headers and heads create this kind of "trouble" sucking in fresh air and causing a "popping" sound?
To sputters/pops when decelerating
Old Apr 5, 2005 | 04:51 PM
lars's Avatar
lars
Peter -
The power valve, when open, is equivalent to an 8-size jet increase. Therefore, on a carb with a PV on the primary side and no PV on the secondary side, you jet the carb with the secondary side 8 sizes bigger than primary. This will then produce equal A/F ratios on both sides of the carb at WOT. If you have PVs on both sides of the carb, the carb can be "square" jetted.
Yes, that's correct: "stock" jetting on that carb is 72 jets, and the size is stamped on the jets. In addition to checking jet size, also check and verify your float levels: with the engine warmed up, pull the bowl plugs and set the float levels so that you just barely get some fuel seepage out of the plugs. A low float level will run you lean and can contribute to the problem.
Lars
Old Apr 5, 2005 | 05:07 PM
lars's Avatar
lars
The 134-21 Secondary plate (stock for your carb) is a .081" Main Jet oriface, which is the same as a jet size 122-75 (#75 jet does not have a .075" hole). This may be a bit lean on the secondafry side based on the #72 primary jetting: If you jet it up on the primary side, you may want to bump the secondary metering plate up to a 134-27 (equivalent to a #80 jet size).
Old Apr 5, 2005 | 08:45 PM
ruby76's Avatar
ruby76
Default OK - don't laugh
Lars, I took the air cleaner off and looked at what I thought the jets were, the brass looking part that sticks out into the "barrel" - sorryfor my terminology. Here is what I found - I drew it in paintbrush real quick as I don't have a digital camera:
The number on these parts are "45R - 107". Did I have it right, is this what the jet is? THen my next question is I don't see 72 on it anywhere but I could be looking at the wrong parts.
