pull plates vs. aluminum intake - recommended?
Old Apr 5, 2005 | 12:07 PM
tersian's Avatar
tersian
Default pull plates vs. aluminum intake - recommended?
What is the recommended method of lift attachment for a fully assembled long block with intake attached to a cherry picker? Is there a risk of stripping the bolts out of an aluminum intake with the weight of a SB using a puller plate?
Old Apr 5, 2005 | 12:11 PM
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
I wondered that same thing. Those are AWFULLY small studs to yank a heavy engine up on. I just yanked a complete big block engine out of my Vette, but I used Grade 8, 3/8 inch bolts on diagonal positions on the manifold-to head locations. They lifted it out no sweat.
Dep
Old Apr 5, 2005 | 12:32 PM
markdtn's Avatar
markdtn
People do it all the time, but I prefer a lift bar so you can tilt it easier. I would be scared of that plate, I'd have a rotten intake and the engine would fall and smush my car.
Old Apr 5, 2005 | 12:38 PM
panchop's Avatar
panchop
i didn't trust them either. I used bolts in the accserory holes on my heads
Old Apr 5, 2005 | 12:40 PM
mandm1200's Avatar
mandm1200
I would be more likely to use a plate with a cast iron intake. I don't like to take chances. A long block has got to be in the 500lb range. That would put an average of 125lb on the aluminum threads.
Old Apr 5, 2005 | 12:43 PM
The Money Pit's Avatar
The Money Pit
I've used this plate many times with no issues,but do recommend grade 8 bolts for insurance.
Old Apr 5, 2005 | 01:07 PM
CGGorman's Avatar
CGGorman
What's the point of using a grade 8 bolt in cast aluminum?
Old Apr 5, 2005 | 01:20 PM
DJ Dep's Avatar
DJ Dep
My manifold was cast iron
But I see your point.
Dep
Old Apr 5, 2005 | 01:49 PM
The Money Pit
The bolts are only 5/16" or so I think,just a precaution. I'm sure the cast aluminum would pull a thread first.
Old Apr 5, 2005 | 01:53 PM
Z-man's Avatar
Z-man
Well, that way if the intake broke and the engine smashed to the ground, at least the bolts would be reusable...
Old Apr 5, 2005 | 02:13 PM
tersian's Avatar
tersian
Here's another angle. What if you have aluminum heads? Still use bolts in the accessory holes? Which holes? Any pictures?
Old Apr 5, 2005 | 03:02 PM
Tom454's Avatar
Tom454
I know that guys use those plates all the time.... but I will never use one. I guess if you calculate the physics of it, with perfect threads (on a 30 year old aluminum manifold ? pft!) maybe it's safe. Just can't bring myself to do it. I use a sling (and leveler) & bolt it to the heads or the block. RE: The aluminum heads... the thread size is usually 3/8-16 or 7/16-14. That's a big step up in size. Also... a "straight pull" on a thread (as in the case of a carb flange) is a lot different than a "shear force" (sideways). When you bolt to the heads, you are adding a shear factor and reducing the straight pull force. That makes a big difference.
Old Apr 5, 2005 | 05:16 PM
joe73vette's Avatar
joe73vette
From an engineer's perspective, the plate is stronger. Four 5/16 bolts in tension are stronger than two 3/8 bolts in shear. Shear strength is half of tensile strength for steel. As far as aluminum, if the bolts are threaded in two and a half times the bolt diameter, the aluminum is as strong as the bolt. One and one-half times for cast iron. So don't worry about the plates. Joe
Old Apr 5, 2005 | 05:42 PM
gkull's Avatar
gkull
I've never used a lift plate and I never remove the hood.
I just use a chain from opposite corners on the intake side of the heads. I've had aluminum heads for years and I have to R&R the motor more than I'd like to.
Old Apr 5, 2005 | 05:53 PM
Tom454's Avatar
Tom454
Cool... great post.
What if the aluminum threads are 30 years old and have been abused by Bubba? e.g.- wobbily studs even when screwed all the way in?
Old Apr 5, 2005 | 05:56 PM
Twin_Turbo's Avatar
Twin_Turbo
I use the lifting hooks that were installed on my 82 engine, if you can, get a set. They bolt to the manifold over the 2 manifold to head bolts that go in the waterpassage on the front & back, they are really sturdy steel pieces and easier to use that bolting down a chain.
Old Apr 5, 2005 | 06:47 PM
stpman's Avatar
stpman
I made and used both a plate and a tilter, I like the tilter a little better for control but wouldn't hesitate to use either one.
Steve
To pull plates vs. aluminum intake - recommended?
Old Apr 5, 2005 | 06:58 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Yeah but four 3/8 in. bolts ( 2 in front and 2 in back ) are the strongest, that's the way I do it, you spend enough money on a motor and a paint job you ain't taking any chances
Old Apr 5, 2005 | 09:29 PM
joe73vette's Avatar
joe73vette
Originally Posted by Tom454
Cool... great post.
Use the heads! LOL Joe
Old Apr 5, 2005 | 10:46 PM
StickShiftCorvette's Avatar
StickShiftCorvette
