pull plates vs. aluminum intake - recommended?
Old Apr 6, 2005 | 12:59 AM
Z-man's Avatar
Z-man
Originally Posted by joe73vette
From an engineer's perspective, the plate is stronger. Four 5/16 bolts in tension are stronger than two 3/8 bolts in shear. Shear strength is half of tensile strength for steel. As far as aluminum, if the bolts are threaded in two and a half times the bolt diameter, the aluminum is as strong as the bolt. One and one-half times for cast iron. So don't worry about the plates. Joe
True, but from another engineer's perspective, the leverage required to tilt the engine is much more easily accomplished when using bolts in the heads - especially if you *really* want to tilt the engine like when installing engine and transmission together...
Old Apr 6, 2005 | 09:15 AM
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
Well let's see...before this manifold plate was invented people were using bolts screwed into various positions of the block without any major disasters for MANY years. At least, I never saw any posts here (or anywhere else for that matter) about engines crashing down on the front of the car or the garage floor. So obviously the engineering theory seems to be negated by practical useage. At any rate, I never have any engineers handy when I'm yanking out an engine
So I'll stick with the grade 8 3/8th bolts screwed in the block or heads.
Dep
Old Apr 6, 2005 | 09:30 AM
redvetracr's Avatar
redvetracr
I have been using the same plate for 25+ years and will continue to do so!!.......I always pull the motor & trans together.......redvetracr
