Polyurethane body mounts
Old Apr 6, 2005 | 01:20 PM
Jclgodale3's Avatar
Jclgodale3
Default Polyurethane body mounts
fixing to drop the body back on...finally! I am using Energy Suspensions polyurethane body mounts and I read in a previous post that some type of "grease"? should be used on the mounts to prevent future squeaks? Can anyone tell me what to use? Thanks
Old Apr 6, 2005 | 01:36 PM
pws69's Avatar
pws69
Energy Suspension makes a silicone grease specifically for their poly mounts. I have never used anything that works quite as good so I would highly recommend using that (and don't be too stingy with it, but don't use an excessive amount whcih would just be a waste).
If you DON'T use it, they WILL squeak!
Old Apr 6, 2005 | 02:21 PM
Jclgodale3's Avatar
Jclgodale3
hmm? Wonder why they didn't suggest the grease when I purchased the mounts? Is there a comparable product that will give me the same results I might be able to pick up locally? Thanks
Old Apr 6, 2005 | 02:46 PM
pws69's Avatar
pws69
I found some at a local Speed Shop place that sells the ES stuff. Summit also has it and they are very fast shippers (usually). Comes in a 35mm film size plastic container. I really have never come across anything similar. It's a VERY stickyish, white compound.
Old Apr 6, 2005 | 02:56 PM
Jclgodale3's Avatar
Jclgodale3
cool...I'll try Seco Performance
To Polyurethane body mounts
