Help me choose a cam...
, without going crazy of course...
, without going crazy of course..."...trying to keep the engine rebuild as cheap as possible and trying to keep it somewhat stock..."
The higher compression ratios will not gain you as much, as spending your money on giving the heads a pocket-porting, and running a roller-camshaft, if funds allow.
Since you're on a budget, I'd do a search on E-Bay, looking for a NEW roller cam still in the box... Basic specs should be ~270-280 degrees of gross duration (~220-230 at .050" lift), lobe separation angle of at least 112 degrees, and lift of ~.450". I'd also look for roller valve-springs online, that'll match your lift... These general numbers will give you a VERY good cam that would idle with a slight lope (depending on ramp profile), give good vacuum to your engine and pull hard up into the mid-range...
Conceivably, you could acquire your entire valve-train well in advance of building your engine, just be being patient and watching for the parts that match your requirements...
Finally, if you can get all that together, I'd recommend an extrude-honing job to your intake manifold, and exhaust manifolds (again, as funds allow). You'll not get the same flows as a high-rise and headers, but it'll look stock, flow pretty well, and nicely support the engine... With 9:1 C.R., DD2000 predicts 370HP, 375 ft.-lbs. of torque. With small-tube headers and a good exhaust system, the same engine (says DD2000) will make 400HP, 400 lbs. of torque...
Anybody that says 35 year old factory cams are great doesn't build or test motors. Kind of keeps their head in the sand. It's 2005!
I have the 186 casting double hump heads all ported and polished, 2.02/1.6 Manley race flow valves, screw in studs, and guide plates. they are surfaced and cc'ed to 64 cc. With .015 steel head gasket and flat top two valve relief forged pistons. My actual compression figures out to static 10.74 C/R with "Iron heads"
Yes, it runs fine on the local 91 octane super unleaded. Because the Crane 238/248 cam with 114 lc bleed off enough pressure do too overlap that the Dynamic compression is 8.2 or something.
I don't have the part number. The Crane web site has it under mechanical solid lifter Power max or something. I also run it with 1.6 roller tip rockers.
Just a sweet running motor. Any questions just ask.
ive decided not to do a roller setup, so im gonna stick with a flat tappet cam. i have it narrowed down to 2
1st-crane P/N113841-duration277/288, @.050 238/248, lift-.480/.500, lobe separation 114*
2nd-lunati P/N40134-duration278/288, @.050 239/249, lift .517/.543, lobe separation 106*
my questions: the duration of these cams is about the same, while the lift and lobe separation of the lunati is higher, from what ive read this is supposed to make more power, but im worried that it will not work with my setup as i read that a lift of .500 or higher will not fit due to piston clearances, is this true? i have to get new pistons anyway-what kind would allow this? is it worth the trouble? i also read that the lower lobe separation angle (like the lunati) will lower the engines "total" compression, so is a piston allowing more compression(~10.5-11) necessary so that the "total" engine compression will be less. (lowering it to a level that will allow pump gas??) i read something about that concept, but i want to make sure i get it right. it is important that the car run on pump gas.
my other concern-i looked up the specs of the stock LT-1 cam and found it to be 300/312, @.050 242/254, lift .435/.453, lobe separation 116*. the lift of this is lower and the lobe separation is higher than that of above, but im worried about the duration of the LT-1 being so much higher--basically i want to make sure im not putting a cam in the car thats going to be inferior to stock.
thanks for all the help, choosing a cam is quite confusing
1st-crane P/N11341-duration277/288, @.050 238/248, lift-.480/.500, lobe separation 114*
Im recommending this cam to a friend building up a 383 with old iron heads. Ideally you want compression up around 10-10.5 to 1 with this cam. Set your quench tight and block off the intake manifold exhaust heating. You will need premium fuel.
The other cam witha narrow 106 lobe separation will make more power but have a lousy idle. The wider lobe separation angle (114degrees) bleeds off compression. This 113841 cam is similar to the original LT1 cam, Id try it.
The Crane cam looks to be a pretty good replacement.
The tight lobe centers on the Lunati cam will probably give you a rough idle so while it might make a bit more peak power, it will have less "LT-1" characteristics. The poor idle/low vacuum might give you problems with the power accessories.
Do not try to compare the GM cam specs to aftermarket cam specs. They are not designed the same way so the characteristics are going to be totaly different. GM cams have long, slow lifting ramps so the duration numbers look strange when compared to aftermarket cams.
I like backdating the engine to '70 LT-1 specs with a few minor mods but it is obviously it is your call.
If you are running headers you might be better off with an aftermarket cam.-Mark.
