Headers: Which dipstick to use?
Old Apr 7, 2005 | 09:10 PM
74FLCONV's Avatar
74FLCONV
Default Headers: Which dipstick to use?
The title says it all. Mounted my headers today and cannot use the stock dipstick tube.
Thanks in advance,
D. Ocean
Miami, FLA
Old Apr 7, 2005 | 09:43 PM
GDaina's Avatar
GDaina
must be something unique to the SB....that is not the case with BB's...
Old Apr 7, 2005 | 10:31 PM
74FLCONV's Avatar
74FLCONV
Well...I'm not 100% sure that I have a stock dipstick tube. It appears so...driver's side, coming up at a slight curve, just outboard of the stock manifold.
Now, with headers in place, the tube needs to curve more inboard.
D. Ocean
Miami, FLA
Old Apr 7, 2005 | 11:31 PM
GDaina's Avatar
GDaina
why not take your tube to the Chevy parts counter and compare? If there is a difference, spend the 10-15 bucks......
Old Apr 8, 2005 | 12:23 AM
74FLCONV's Avatar
74FLCONV
Here's mine (courtesy of Eckler's which they say is stock):
And here's another they list as "stock":
I think the straight one would do it...
D. Ocean
Miami, FLA
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Check out Lokar. They make some custom ones that are short style. They also make a dipstick that has no tube. The stick goes into the block it's self and you pull the whole stick out instead of pulling a stick from a tube. It stays in place with rubber o-rings.
Old Apr 8, 2005 | 10:36 AM
Z-man's Avatar
Z-man
Wait a minute - can't you just rotate the tube so it is oriented correctly? My stock one works fine with headers...
Old Apr 8, 2005 | 10:39 AM
76texvette's Avatar
76texvette
Just put Dynomax headers on mine.....did not have a problem with the dipstick tube.
Old Apr 8, 2005 | 10:42 AM
djgrelli's Avatar
djgrelli
I installed a Lokar Flexible Billet dipstick. Dresses up the engine compartment. It is a little pricey, around $42.00
Old Apr 8, 2005 | 11:09 AM
chuck d's Avatar
chuck d
Default Dip Stick Tube
That straight piece I believe goes down inside the dipstick hole. It acts as a guide for the dip stick as it goes down into the oil pan. That curved piece looks like the proper upper dipstick tube.
Chuck D
Old Apr 8, 2005 | 11:18 AM
1970-Bronze's Avatar
1970-Bronze
D. Ocean
Miami, FLA
I agree, couldn't you just turn it so it poinst more towards the front?
Old Apr 8, 2005 | 11:21 AM
CGGorman's Avatar
CGGorman
Just bend it.
Old Apr 8, 2005 | 10:55 PM
74FLCONV's Avatar
74FLCONV
I tried that. If I rotate it forward, it hits the center set of tubes where they exit the head. Tried every possible angle and it hits everytime.
D. Ocean
Miami, FLA
Old Apr 8, 2005 | 10:56 PM
74FLCONV's Avatar
74FLCONV
Originally Posted by CGGorman
Just bend it.
Tried that, but it' pretty sturdy stuff. I'm afraid if I try too hard it will kink instead of bend.
D. Ocean
Miami, FLA
Old Apr 8, 2005 | 11:24 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
D. Ocean
Miami, FLA
i don't have this problem with my headers or dip stick tube???? but if i were to bend it i would put a another tube inside of it to stop the posibility of kinking it....
Old Apr 8, 2005 | 11:39 PM
74FLCONV's Avatar
74FLCONV
Never heard of that trick. I'll give it a try.
P.S. - Sending your washers out in the next few days.
D. Ocean
Miami, FLA
Old Apr 8, 2005 | 11:40 PM
bobs77vet's Avatar
bobs77vet
D. Ocean
Miami, FLA
thanks I appreciate it. bob
To Headers: Which dipstick to use?
