Cutting Front Springs
Old Apr 11, 2005 | 11:15 AM
mooneyd's Avatar
mooneyd
I wish I knew all this before I put in the 460 lbs. springs. Now my ride height is too high I can't remove and cut them myself so It would cost me to pay someone. I think I'll leave it for a while and see if the springs settle down at all. If I lower the front and back will I have to redo the wheel alignment?
Old Apr 11, 2005 | 08:40 PM
lvrpool32's Avatar
lvrpool32
I have the 550lb springs (VBP) and would like to lower it another .5" Would cutting these springs be the same process as the stock ones?
Nick
Old Apr 11, 2005 | 08:44 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
you're not the only one - I removed and reinstalled the front springs a few times until I had it the way I want it...
Old Apr 11, 2005 | 08:45 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Nick
I'd start with 1/4 or 1/3 coil - cut the bottom end and don't get too much heat into the material
Old Apr 11, 2005 | 08:49 PM
Red73's Avatar
Red73
I'm thinking that I need to cut another 1/4 coil from my front spring to get the stance I want. I'm going to drive it first to see if it settles another .5-1" before cutting more. Rod
Yes, I know, not safe to be on blocks. I only had it on blocks to see how the stance was, the vettes back on the jack stands. Rod
Old Apr 11, 2005 | 09:12 PM
73jst4fun's Avatar
73jst4fun
The stance looks really good now Rod, did you have 15"OEM wheels on before you went with 17" wheels....Jay
Old Apr 11, 2005 | 09:19 PM
Red73's Avatar
Red73
Jay, No, I had 15" AR TT IIs. Rod
Old Apr 11, 2005 | 10:59 PM
gkull's Avatar
gkull
Rod - Do you have gas charged shocks that could be causing lift also? You might be at the point where you need the shorter front tubes.
I'm going to shorter ones because - About a week ago after messing with spring spacers I blew the end of the sway bar off and it destroyed a shock. Oil everywhere when it bottomed out.
Old Apr 11, 2005 | 11:17 PM
Cali,68,L-79's Avatar
Cali,68,L-79
I cut 1.5 coils off my front coils and I have 26" on the front. See pic below.
Old Apr 17, 2023 | 08:29 PM
John Vance's Avatar
John Vance
Default Top or bottom cut.
okay I’m confused. I’m lowering my 79 front end. I understand 1” coil cut gives 2” body drop. I don’t have clear understanding of which end to cut? Top or bottom. This forum says both ways? Also it’s not critical to seat the BOTTOM just the top of the spring???? Help please!!!
Old Apr 17, 2023 | 08:45 PM
Mooser's Avatar
Mooser
Best to start a new thread rather than re-opening one from 2005.
If it's a variable rate spring, cutting the loose coil end gives a slightly harder ride and you'll get a little more drop, cutting the tight end gives a slightly softer ride and you'll get slightly more less drop
Make the spring fit the top pocket and make sure the bottom isn't sitting where it's completely out of the tapered pocket, if it is, rotate it some out of the top to split the difference
M
Old Apr 17, 2023 | 09:29 PM
John Vance's Avatar
John Vance
Default Cut springs
M
moser. Thanks for the response.
Old Apr 18, 2023 | 05:40 PM
  #33
btwick's Avatar
btwick
Here is a link to a thread I started recently on this topic. A lot of good feedback wrt cutting coils and ride height in general. Good luck.
https://www.corvetteforum.com/forums...conundrum.html
