Outside lock removal
I have two problems that haven't really been adressed.
1) The outer door lock turns freely and does not put torque to the lock mechanism. I know I need to replace this...Here's the problem: I purchased some fishing pliers and can grab on the clip, it just won't move. Do I need to just pull harder? I feel like I could screw up the fiberglass if I pull too hard.
2) I also have problems with the outside handle. The spring that is attached to the handle is no longer attached. Does anyone have a picture of where the spring for the outer handle attaches to the control rod? If I order a new door handle does it come with the spring attached and a new rod?
Thanks for advice!!!!!
Once you get the old door handle out of the car it will be pretty obvious how the rod and spring go in there, but a new latch handle should come completely assembled (rod and spring in place).
