I'm thinking about putting insulation on the outside of the fanbox or heater box , I'm not sure what the area is call -- under the hood, where the a-c, heater fan motor goes into the firewall. Is this worth the effort?? Has anyone done this?? Could you tell any difference?? What did you use?? I've read about Frost King -- would this hold up to the heat coming off exhaust manifold??
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i did it this winter using "zero clearance" and its holding up fine...can't really tell if it made a difference but i would suspect it would.
I did it. Used the "zero clearance" product. I custom cut it to fit. Made a pattern first; it has an adhesive backing and is very durable. Installed it on the bottom of the housing and on the side adjacent to the exhaust manifold. I sprayed it satin black. It has held up very well and is not noticeable.
It HAS to help. The fiberglass housing would get so hot from engine heat I could not touch it. The zero clearance has to eliminate some of the engine radiant heat that soaks into the C3 interior; suspect it also helps the air cond. run cooler. Every little bit helps!
I just did this with DEI floor and tunnel shield. (Summit part no. DEI-050502). It's only 3/16" thick, has an embosed aluminium (can be polished) skin backed with fiberglass and is self adhesive. It withstands temperatures up to 1750 F.
My headers were actually burning my heater box. No problem now. I used the self adhesive and reinforced it with ss screws and washers.
Call me silly, but I took the 1200 degreee ceramic aluminum duplicolor spray paint and coated the inside and outside of the box before painting it black. I coated the manifolds with the same paint and it significantly reduced the temp under the hood...
Here's how you tell if you need to insulate the box (or how well your insulation is working):
Remove fan speed resistor bank just high enough to slip temperature probe in. This spot is upstream from the heater core--so it should not effect temperature probe.
1. With car cold, turn a/c to VENT/HI FAN and measure the temperature going into the box, then move probe to the resistor bank hole. Now close hood.
2. As engine warms up, note temperature. It should not rise. If it does, check for a bad hood seal first.
3. Now measure temperature at the interior vents. If there's a heat rise, your heater water valve is disconnected, or otherwise not getting a vacuum signal, or is leaking by. If you have a vacuum leak anywhere in your a/c control system, the water valve and heater door will open upon brisk acceleration--causing a heated air pulse.
I insulated mine, and I have no heat rise at all. They are insulated in most newer cars. The accumulators are also insulated as well as the suction line to the compressor.
