Today, I noticed that one of my front calipers is leaking. Time for new brakes. I would like 13" rotors. What are my options? Precision Brakes sells a kit, but over $3k seems a lot for brakes when the calipers are under a grand.
They are about your only option, the other one would be to have a race outfit like coleman machine custom hubs, get the 13" rotors to match and buy calipers & make your own brackets, or have them made.
Unless you are into some serious racing, I see no need to upgrade the brakes on these cars. Unless of course you want the WOW factor from other or you just like making your own stuff. These brakes are good enough to stop your car. You really can't beat a 4 piston caliper unless you got to 6 or 8 piston.
If you don't want to spend the 3K, then you are pretty much on your own for making brackets and using coleman hubs and rotors like TT said. Your other option is to use C5 rotors and calipers. Again you would have to make brackets and they are only marginally better than a properly operating stock system. Not really worth the trouble unless you want the wow factor as Van Steel said.
What about SSBC Force-10s. They would be a lot cheaper, especially since I can use my stock rotors. The weight savings is what I am looking at here. What do you guys think?
Those are good calipers. They bolt right on. Give you better stopping power. They are aluminum(light weight) and use bigger pistons. The weight savings on those is 20 lbs if you buy all 4 BUT they are also expensive. $750 for a set of 2.
I was looking around for options and found this thread from a while back. Sounds like VBP is working on C5 brake to C3 chassis kit, anyone ever hear more about that?
The guys at touring classics came up with a killer Billet bracket to adapt C5 brakes to a first gen Camaro. I was able to turn down my hub just a tad and drop the conversion right in place. It is awesome! I am really hoping somebody else comes up with this for the C2 & C3 as it is really such a simple piece to make it all go.
Why? When you run huge on large rims with narrow spokes, the little stock rotor just doesn't do it for me. I am running 17" front and 18" rear on the Camaro, so the big brakes were a natural choice, plus the price was VERY reasonable ($80 for the bracket kit, then everything else was over the counter GM parts or Ebay, etc).
Here is a pic of the C5 stuff shanked on the 1st Gen Camaro. Man...I hope they make this for our C3 Soon!!!!!!!!!
Have you tested these yet against another vette w/the stock 4 piston or Force 10 aluminum calipers? I still have trouble believing that a 2 psiton caliper can stop better than a 4 piston caliper.
I am still working out the master cylinder.
After breaking out the ol physics book and doing some calculations, it shouldn't matter if they are 2 or 4 piston due to the design.
With the same line pressure and the same piston diameter the pistons will exert the same force onto the pad regardless if 2 or 4 piston. This is because the pressure pushing the piston is also pushing back on the sliding caliper applying force the the other pad.
The C5 pistons are larger than the C3 pistons meaning the C5 calipers would give more clamping power for the same line pressure.
Now the down side. By going to larger pistons in the calipers, you would require a smaller master cylinder bore to get the same line pressure to actually increase your braking. This explains why my pedal effort was more with the C5 calipers.
Well if money isnt an option for you guys, the best brake company in the world (arguably) MoveIt Brakes, makes a full on kit for C3s, unfortunately if you want to do front and back, it will cost you $5000 EUROS hahahaha. You will have the best brakes ever put on a C3 though...
Um, better go back and look at your basic hydraulics book again.....
PSI is PSI it's not an inverse relationship. Design your MC for 1000psi at 150lbs force on the pedal and you will be close. In other words more piston area means a larger MC. I think you are calculating your piston area wrong.
There are also some formulas that can tell you exactly what you brake torque is and what it should be ( ~2200 ft/lbs for the front of a Vette )
Add up the piston area of one side of the 4 piston caliper and compare that to the single piston caliper.
