Help ID this part..
Old Apr 12, 2005 | 11:20 AM
Chumpzilla's Avatar
Chumpzilla
Default Help ID this part..
Came off a '79. No idea what it is. Any help is appreciated. I think it's an interior piece, but that's a WAG.
Old Apr 12, 2005 | 11:30 AM
Twin_Turbo's Avatar
Twin_Turbo
That's the steering column to firewall bracket, it goes on the engine side of the firewall
Old Apr 12, 2005 | 11:39 AM
Chumpzilla's Avatar
Chumpzilla
Thanks. Thought it might be steering related. That answers a couple of questions actually.
Old Apr 12, 2005 | 11:40 AM
Chumpzilla's Avatar
Chumpzilla
Which side is up, or is that easily figured out once you crawl under there to look?
Old Apr 12, 2005 | 12:06 PM
Twin_Turbo's Avatar
Twin_Turbo
The stud goes into the interior.
The column sits in the round cutout, the bracket supports the underside of the column. The stud and anchor bolt go through the oval shaped plate on the column that has the insulation stuff on it
Old Apr 12, 2005 | 12:11 PM
Chumpzilla's Avatar
Chumpzilla
Thanks again TT.
Also helps answer a previous question I had asked... and that's where the clutch return spring connected on the firewall. I'm guessing it attaches to that loop/hole on the top of the bracket in the top pic... or to some additional bracket that attaches to this one in the same location.
To Help ID this part..
