Windshield install...
Old Apr 12, 2005 | 05:09 PM
DonBecker's Avatar
DonBecker
Default Windshield install...
Has anyone on here installed a windshield in their C3?
Can I use some generic sealer stuff from a local windshield shop?
What size sealer? Any other info?
Would like to do it right the first time...
Old Apr 12, 2005 | 05:47 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
Personally, I won't mess with a windshield, although I know others do. Sometimes I just feel better leaving certain things to a pro. I've heard of these things blowing out at high speeds due to improper installation.
Old Apr 12, 2005 | 06:40 PM
keith72's Avatar
keith72
Safe t lite did mine for $204, including the windshield and installation. They came to the house and did it. Of course, that's not for a date-correct windshield. But it was worth the price.
Old Apr 12, 2005 | 06:43 PM
NHvette's Avatar
NHvette
Stock from the factory used Butyl rubber ribbon to set the glass.
You can still buy it, but the material of choice now-a-days is
urethane adhesive.
3M Window Weld ... available at good parts and auto paint stores.
The important thing to get right is the installed height - up off the WS frame.
If not right, the stainless trim will not fit properly.
You can use small rubber blocks to space the glass properly.
That said, I will be paying someone to install mine.
Old Apr 12, 2005 | 07:37 PM
DonBecker's Avatar
DonBecker
Any on ideas on the cost for someone to come out and put it in?
It's out now (I painted the frame with POR-15) and all cleaned up, ready to go back in.
I want to make sure I get it right (or get the right person), I want to eliminate water leaks.
Old Apr 12, 2005 | 08:29 PM
hiyosilver's Avatar
hiyosilver
Default windshield
The only comments i have for you are ask around your local area .
If there is alocal corvette club certainly someone has had a windshield replaced or knows someone who has .
Old Apr 12, 2005 | 09:02 PM
rponfick's Avatar
rponfick
NHvette is correct. I asked the installer from Elite Auto Glass if they would get the height right and he said no problem. He just squirted the adhesive out on the windshield frame and installed the windshield. I thought it looked a little low, but now I'm stuck. The upper chrome moulding is now too far from the glass. I think I can get the side moulding close enough. Sure is sealed well however. Oh well.
Old Apr 12, 2005 | 10:18 PM
Big Fish's Avatar
Big Fish
NHVette makes a very good point. Many of the installers out there may not be familiar with our C3's. If you can be there when the installer shows up and explain to him exactly what is expected and how it must fit he will probably get it right. There might be measurement tolerances in the AIM?
Old Apr 13, 2005 | 06:31 AM
DonBecker's Avatar
DonBecker
There are tolerances...
Old Apr 13, 2005 | 07:16 AM
Ybnormal's Avatar
Ybnormal
I took mine out myself, that was a task in itself, never again will I try that I also paid $200 for a local windshield company to come out and install new PPG glass. He said he could have taken it out for $65 and saved me the two weekend it took me to get it out. He used an electric caulk gun and laid down a bead around my prepaired frame and installed the glass. When I went to put the trim on a few days later I also had a large gap between the top frame and glass. Thinking back now or if I ever do it again I would use spacers to get the glass to the correct position, then have them install the glass onto the spacers. Oh well it doesn't leak
YBnormal...drive a vette
Old Apr 13, 2005 | 07:32 AM
pws69's Avatar
pws69
I did mine with a friend a couple of years ago and it came out quite nice. I did use Butyl Tape AND Urethane Sealer AND spacer blocks. The molding fits and contacts perfectly all around and there are no leaks.
You need to take your time, dry fit glass and trim to get a "feel" for your car and how deep the glass needs to be. It's really not a bad job but you definitely need patience and a helper. I actually started a writeup with pictures, but never got around to finishing it.
Old Apr 13, 2005 | 10:40 AM
NHvette's Avatar
NHvette
You're killing me here. I love to do everything myself ... but too much to do.
Sounds like you did a nice job.
What did you use for spacers ? Just cut some small blocks of rubber ?
I'm fairly sure you can't buy those spacer blocks anymore ... could be wrong.
Old Apr 13, 2005 | 11:15 AM
pws69's Avatar
pws69
Another friend had a few rubber spacer blocks laying around. I couldn;t find the "Special" spacer blocks which, from what I could find out, were "stepped" and possibly screwed in at two bottom corners.
You are correct - I searched all around the country (really!!) for some of the "correct" spacers to no avail!
I'm killing you???? How about that frame work you did.....
Old Apr 15, 2005 | 02:08 PM
pws69's Avatar
pws69
Well, as I stated in a previous message, I took pictures during the install - but never made them available. I started feeling guilty (no feeking idea why!!) so......
I put this together for all YOU brave folks who want to give it a shot!
http://www.speakeasy.org/~pws/Corvette.htm
It's really not a bad job at all!
Good luck.
Paul
To Windshield install...
