Line Lock Solenoid Positioning
Old Apr 12, 2005 | 11:05 PM
nastee383's Avatar
nastee383
Default Line Lock Solenoid Positioning
Does a line lock solenoid HAVE to be positioned upright? Can it be horizontal without any ill effects? The inlet is on the top and the outlet is on the bottom when it is in the upright position. (B&M)
Old Apr 13, 2005 | 11:10 AM
johns73's Avatar
johns73
Hello
I'am about the same thing, also with the B & M. Where do you plan on mounting it? I have not looked into where to mount it yet.
Old Apr 13, 2005 | 11:58 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Mine is mounted upright, but I can't imagine that it matters how it is installed...
Old Apr 13, 2005 | 12:48 PM
norvalwilhelm's Avatar
norvalwilhelm
I mounted mine directly below the master cylinder. Remember it uses Pipe threads so you need adapters and teflon tape to seal the threads.
Do not try screwing brakes lines in directly to the line lock.
I can't imagine it cares how you mount it. It has 2 outlets for the front brakes and one inlet from the master cylinder. This is a good time to remove the proportioning/light switch from the system. Remove it and plumb the rear brakes directly to the rear and the front of the master to the line lock and twin outlets to the front brakes.
This will improve brakeing and safety.
Old Apr 13, 2005 | 02:10 PM
Corey_68's Avatar
Corey_68
Probably doesn't amtter but I have mine right below the Master cylinder upright.
Old Apr 13, 2005 | 03:09 PM
Sharky Guam's Avatar
Sharky Guam
yep, it does not matter as long as you bleed all tha air out of it.....and yes on the fittings....you need to go from pipe thread to the flare.....
Old Apr 13, 2005 | 04:15 PM
The Dude's Avatar
The Dude
Doesn't matter. However make sure you install it according to the NHRA rules.
The last I heard those rules specified that the line lock must be installed in the system AFTER the pressure diffeerential stitch and/or proportioning valve.
You might want to double-check.
Old Apr 13, 2005 | 07:34 PM
nastee383's Avatar
nastee383
Thanks guys.
To Line Lock Solenoid Positioning
