2004r Shifter Question.
Old Apr 12, 2005 | 11:34 PM
munday's Avatar
munday
Default 2004r Shifter Question.
Still have the stock 79 shifter. Will I be able to use it and just lose direct access to first gear? Don't have 200 bones to drop on a quicksilver shifter that I want.
Old Apr 12, 2005 | 11:37 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
can't speak for the 2004r but on my 700r4 swap on the 77 i don't see how it would have worked so you could get all the gears using the old detent
Old Apr 12, 2005 | 11:46 PM
C371's Avatar
C371
BTO (Bowtie Overdrives) sells a replacement indexing plate and shift indicator for around $100 or less. You shouldn't need to spend $200 on a Quicksilver.
Old Apr 13, 2005 | 12:40 AM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
and it's a-ok.
Old Apr 13, 2005 | 06:38 AM
redwingvette's Avatar
redwingvette
The shift patten for the 200 is setup different thn the stock shifter. The full travel distance is the same, where they ar different is P-R-N-4 is closer together to make room for 3-2-1. Because of the shorter distance it makes it possible to have the detent on the shifter to put the trans in an in-between gears state, not a good thing. You could grind the stock detent to make it work but it would be a lot safer to get the new detent from BTO. To install it is simple.
Old Apr 13, 2005 | 08:14 AM
bobs77vet's Avatar
bobs77vet
i installed mine by taking the two side consol panels off and drilling out the two spot welds and then putting in the new detent from BTO....took about 1 hr.....i did not dissassemble the shifter
Old Apr 13, 2005 | 08:29 AM
isosceles's Avatar
isosceles
I bought the kit from BTO. Comes with a new indicator plate too.
Old Apr 13, 2005 | 09:32 AM
bobs77vet's Avatar
bobs77vet
heres the visual
[IMG][/IMG]
[IMG][/IMG]
Old Apr 13, 2005 | 11:18 AM
PatsLs1vette's Avatar
PatsLs1vette
i used my stock shifter and filed the detent lower so i have first gear i can use all 4 gears in the stock console and shifter.
To 2004r Shifter Question.
