Is this tech related?
Old Apr 13, 2005 | 11:11 PM
Cali,68,L-79's Avatar
Cali,68,L-79
Default Is this tech related?
http://forums.corvetteforum.com/show....php?t=1063992
Not sure so posted in gen. No answers in gen, not Zymol related I guess. Thought someone here might know.
Old Apr 13, 2005 | 11:21 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i'm just running mine to the big port in the base of the carb in the back through a 3/8 line and don't seem to be having any problems...i have no special PCV valve that i know of....
Old Apr 13, 2005 | 11:24 PM
Cali,68,L-79
Same here. Damn suction's so strong it'l rip the skin off your hand. never seen that before. The resrictors working though, idles 800rpm, suction at idle has PCV piston at 50% open, kind of close but no cigar.
Old Apr 13, 2005 | 11:33 PM
bobs77vet's Avatar
bobs77vet
i didn't know there was any specs for those things i thought they were just a "go/no go " item
Old Apr 13, 2005 | 11:38 PM
Cali,68,L-79
that's the problem. There's no guidance on such a simple part but each has a specific vacuum range. As for now I have 4 PCV's sitting on the workbench and I'm sticking to the "Bubba resrictor" since it seems to wrok but it bugs me.
Old Apr 13, 2005 | 11:41 PM
bobs77vet's Avatar
bobs77vet
when you square it away let me know the part number you get and i'll follow you....i'm also pulling 16* at idle
Old Apr 13, 2005 | 11:42 PM
Cali,68,L-79
what's your oil consumption like??????
Old Apr 13, 2005 | 11:48 PM
bobs77vet's Avatar
bobs77vet
wells its a new engine with 675 miles on it , i have changed the oil once already and i have added 1 qt so far in the break in period.
Old Apr 13, 2005 | 11:55 PM
Cali,68,L-79
bob to give you an idea. before with push in breathers I went thru 1/4 quart in 1000 miles, now it's 1/2 quart in less than 500 miles. If I'm forced to I'll go back to push in breathers but PCV's are so much cleaner, those breathers have always leave oil mist all over the chrome when "hotdogging" it on all 3 Vettes, my Mustangs etc. Reason why I switched. Just need to find the right stiff spring in the pcv for 16" vacuum. Someone out there knows the answer.
Old Apr 14, 2005 | 09:53 AM
rihwoods's Avatar
rihwoods
This may help.They list PVC "kits" for various 68 Vette engines.Just click on "parts index",then on "P". About $16, but no spec quoted for valves.
http://www.docrebuild.com/dr-r-web/aaa-home.html
Old Apr 14, 2005 | 10:07 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I never gave the PCV valve much thought. Go to the store, buy one, remove the old one and put the new one in. 15lb on this new engine and 0 oil consumption after 500 miles.right now I'm using a PCV that's inside an oil breather.
Old Apr 14, 2005 | 11:07 AM
bobs77vet's Avatar
bobs77vet
i hate the smell of push in breathers and will never have them.... are you valve covers baffled where the PCV valve fits in?
Old Apr 14, 2005 | 11:57 AM
Cali,68,L-79
Yeah sort of, there's a half-*** baffle but honestly poorly designed and yes oil splash could get in there.
Old Apr 14, 2005 | 12:13 PM
bobs77vet's Avatar
bobs77vet
i will wager thats more of an issue then vacuum pressure....
To Is this tech related?
