Door panel removal
Old Apr 15, 2005 | 06:44 AM
foundvettelifeisgood's Avatar
Default Door panel removal
I need to pull my interior door panels and remove the outside door handles. Any tips?
Old Apr 15, 2005 | 07:07 AM
fast idle's Avatar
fast idle
i took mine all apart 3 years ago, i'll be interested to know how to re-assemble the new ones.(maybe i'll hold off till u get yours).
Old Apr 15, 2005 | 07:13 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
If you have manual locks and windows, you'll need to get the special tool to release the handle & lock from their shaft.
Old Apr 15, 2005 | 09:09 AM
crazydalys's Avatar
crazydalys
Don't forget about the screws in the door handle, I missed those, and started yanking on it while they were still in there
Old Apr 15, 2005 | 01:01 PM
KALAWAY's Avatar
KALAWAY
I have the tool but don't know exactly where the clip is that you have to remove.
Old Apr 15, 2005 | 07:19 PM
Does the auto parts store have the tool, or is it Corvette vendor time?
Old Apr 15, 2005 | 07:46 PM
Jughead's Avatar
Jughead
St. Jude Donor '09
Should be able to find it at Auto-zone or Advance auto. It's a thin tool that slides between the panel and the handle. It's job is to release a U-shapd, small clip which hold the handle to the shaft.
Good luck.
Old Apr 16, 2005 | 08:45 AM
FeedVaal's Avatar
FeedVaal
I use a spare rear trailing arm shim, Works great.
Old Apr 18, 2005 | 01:04 PM
Casper's Avatar
Casper
I've had mine off many times fixing different stuff. Swapped out the orginal ones this weekend with new Al Kocke. That was a chore.
Old Apr 18, 2005 | 02:50 PM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
Good luck.
I made a tool out of an old straight edge screw driver and a vice. Just made the end of the driver look like a "j". On the very end of the driver, probably only the last 3/32 or so of the flat edge.
A-zone etc will also have "replacement" window handles and clips if you want to see what your fishing around for.
To Door panel removal
