Compatible brake boosters
Old Apr 16, 2005 | 12:21 PM
70 LS1's Avatar
70 LS1
Default Compatible brake boosters
I am interested in doing a power brake conversion. What boosters from other cars will work with little modification? Not Hydraboost.
thanks
Old Apr 16, 2005 | 03:08 PM
dman535's Avatar
dman535
Why are you against doing a hydroboost ?
Old Apr 17, 2005 | 02:56 AM
70 LS1's Avatar
70 LS1
I don't have power steering and don't want to install the pump.
Old Apr 17, 2005 | 09:14 AM
markdtn's Avatar
markdtn
From looking at Hollanders there is no other direct interchange than a Vette. There are 4 different flavors of booster: 68-76, 77, 78, 79-82 according to them. They will all bolt into any C3, you just have to use the corresponding master cylinder. I have a 79-82 setup in my 69. 68-76 were painted black, 77-82 were anodized originally but when I got mine from CarQuest it was just natural so I painted it. The only reason I have a later one is that somebody gave me a booster that was supposed to be good, it wasn't-but by the time I figured it out the system was already bled.
Why use something different? It is pretty easy to just buy a combo for a C3 and put it in.
Old Apr 17, 2005 | 10:44 AM
70 LS1's Avatar
70 LS1
Trying to save a little money. Seems everything that is for a Corvette is more expensive.
Old Apr 17, 2005 | 11:06 AM
PROSOUTH's Avatar
PROSOUTH
From: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
I haven't tried to do an install on a C-3, but we use a lot of S-10 Chevy boosters and MC's on street rods.
They are very small and the aluminum MC is lightweight. They are plentiful and in-expensive. I believe it might work. jim
Old Apr 17, 2005 | 12:16 PM
70 LS1's Avatar
70 LS1
I am going to use a C5 master cylinder. The C5 booster looks like it would fit, but the rod that attaches to the pedal looks way too long.
Old Apr 17, 2005 | 03:02 PM
markdtn's Avatar
markdtn
Late 70s/early 80s "B" bodies (Impala, Bonneville, etc) boosters are very similar in appearance but keep in mind you need a master cylinder for front and rear disc brakes. A drum brake m/c will not have enough volume for the rear discs. That pretty well limits you to Vettes and some Camaros/Firebirds until the mid/late 90s. A rebuilt booster/master cylinder combo for 79-82 is $100 from AutoZone with a $30 core. Booster itself is $84 and a new m/c is $90, used is $16. So rebuilt booster and new master is only $173. You can probably find a better deal on a used booster on Ebay. Good luck with it.
To Compatible brake boosters
