SH*#$Y Demon carb
A strange things has been happening when I accelerate hard and let off the gas. When I go back into the throttle there is nothing there, its as if the motor has loaded up and died. I can pump it an nothing. It takes a couple moments to come back and then it runs fine. No real part throttle or idle problems, just when you accelerate hard.
What it felt like to me was the that the pump shot was dry.
So why the motor is still hot I figured I would go check it out.
I started the car and it was idling fine and I moved the primary throttle blades and there was no pump shot, it took 5 or more pumps to get any fuel to come out, and I noticed when the throttle blade returns there is still fuel seeping out from the squirter.
The primary pump shot seemed really weak for some reason as well.
The secondary pump shot was a strong squirt and looked to be working fine. I pump the secondaries a few times to make sure they are working, and when I let off the throttle the squirter just kept squirting fuel into the secondaries.
After that there was no pump shot for a couple movements of the secondary throttle shaft.What the hell is going on here, I have never seen this before.
Some suggestions would be helpful as I am at a loss as to what is going on here.
Thanks!
What caused the carb to previously empty the bowls into the motor overnight?
The previous carb was a mystery, BG never gave me a reason why it would do that...
Hows your valve lash?
Now, before you dismiss this idea, consider the following:
1. If the problems were isolated to ONE carb, then I'd say your carb had a flaw... But you're on #3, and STILL having various issues... If you were on your third Holley #3310-4, I'd say to send them back, and get a BG. Frankly speaking, while the BG carbs may occasionally have an issue that needs correction, I refuse to believe that 3 of them all have the same problem... It's not the carb, it is another fuel-related issue.
2. You're getting unwanted fuel-flow from your squirters.
3. When coming off of high RPMs and load, the fuel demand suddenly drops, but the flow of fuel into the bowls continues to stay at a high rate... You try to pump the carb to force the engine to run, but it only dumps in MORE fuel, making an already-rich condition worse...
So the question is, are you running a high-volume fuel pump? Max pressure of the fuel supply should be 6-8 pounds, and NO more... What is your line pressure???
Do you have a fuel filter between the carb and the fuel pump? Have you checked it for any blockages???
Did you use teflon tape to seal the line fittings? A common mistake (and one I've done TWICE) is to have little bits of teflon get into the fuel system and clog the metering blocks...
My honest opinion is that your fuel pump is delivering too much pressure, pushing the needles off of the seats and drowning your engine (when running on the road)... As to the other symptoms, I'd wonder if there's a blockage in your metering blocks...
I hope I was able to help...
Eric
The fuel pump I am running is a Mallory Comp 110 electric pump, a very well built piece and I don't think it is the issue. If I was running out of fuel it would go lean as I keep accelerating, I can keep into it past 100 and it will keep pulling. Fuel pressure is set at 6.5lbs. I did not use any teflon tape on any fittings, I am using the Russel sealant. The fuel filter was checked and is clean from debris.
I will try a few things and report back if I find it, the diaphram may be damaged for one reason or another so I will check and replace it if I need to.
The needle and seat may be sticking open and when I let off it is feasible that the motor is loading up.
I'm not done with it, but I am eyeballing a Dominator..
Thanks!
Naturally restarting was difficult.
It turns out that at high RPM, fuel was gushing up out of the fuel vent tubes becuase there was some trash stuck in the float valves. It took a few times for this to happen before I figured it out.
Also, changing to an electric pump helped solve some starvation issues I was having due to a bent pump pushrod.
As far as your problem... is sounds fuel related. Check your fuel line...make sure you are not losing pressure there... open the sight holes on the carb when you are on level ground...Your float level should allow fuel to just trickle from the sight hole....if the float is stuck it will use the fuel in the bowl and then cut off.... if you line is kinked or losing pressure it will not be able to keep up with demand.
The gas tank is perfectly clean, no debris, rust, nothing.
Also, the float bowls are consistent, no changes in level when running.
I checked the linkage and found the secondary accelerator pump was bottoming out at WOT and even before then. It took a fair bit of adjustment to set it so it did not bind. This is strange because I just checked this when the carb was off the car and there was no binding, I had the .020" of movement after the throttle shafts were fully open.
I am unsure as to why that would of changed, but it did. I also removed the squirters and found a small piece of red gasket in the secondary squirter. I cleaned both of them out and after I readjusted the accelerator pumps it is not doing it anymore.
Thanks!
I've worked on more Holley carbs than I can count... New ones, old ones, rebuilds, tuning, etc... My favorite is the old 3310-0 or -1. Later carbs (remember the 4010/4011 "modular" design, for example?) suck, BAD. A variety of quality-control issues, that make them unreliable, and miserable to tune...
If you're using an old-style 1850, then yeah, they DO work ok out of the box... But anything more sophisticated than that, and BG carbs make the Holleys look like what they are: garbage.
You or I, if we had the technical know-how, could utilize the old Holley technology, and if we found a new way to improve the atomization of the fuel, or achieve some other new process to otherwise improve performance, we could patent it...
Just like BG did.
And while BG's carburetors across all lines are superior to Holley's popular lines as far as components, BG has some quality issues that they have yet to come to grips with. Holley isn't perfect but they're a lot closer to a functional out of the box product than BG is. Not completely unexpected given that BG is, for the most part, a start-up company with a great product but is having difficulty some manufacturing issues. One real benefit of BG entering the carb manufacturing business is that they have forced Holley to step up to the plate as far as moving their product line along.
