Halogen Tail Lights...don't get them!
IMHO...I am going back stock....
I got them at www.sherco-auto.com .
I have never heard of 2057's. do they have the same conectors?
http://www.lightlens.com/coloredbulbs.htm
I'm messing about with LEDs at the moment. I'm trying to run 4 tail/stop lights by using 4 of the backup light lenses. In the center I was going to have amber bulbs in the outer pair as direction indicators & clear bulbs in the inner pair as backup lights. Then I can get rid of the lights hanging under the car. The tail stop will be taken care of by rings of LEDs mounted in a circle in the backup lights so that they point rearwards. What I've found is that 12 LEDs do a really good job as tail lights but I really don't think that they're brint enough for brake lights. On a sunny day I think they could get lost in the glare & at night they ain't much brighter than they were as tail lights. LEDs are very directional & when looking at them straight on they don't look bad. But from an angle, however slight from straight on, they don't look as bright. When compared to a normal 21W brake light sitting next to them they look dim. I'm trying LEDs with a wider viewing angle but the problem there is that the brightness drops off with the LEDs that have decent viewing angles (those that I've found so far). In short, I wouldn't bother with the 12LED stop/tail LED lights. My next step is to buy a 19LED bulb & see how that looks (all the LED bulbs I've seen are marked "Off road use only" so I guess that they're not quite legal?
not true of the LED things though, at least I hope not...better not be....
GENE
Has anyone seen a combination white/red led? I'd like to keep the backup and have an extra brake light as well.
Bob, thanks for the reply. Our standard stop/tail bulbs (offset pins like a 1056?) have a 5W filament for tail & 21W for stop. I've fitted LEDs to one lamp & used 2 resistors, one letting through a little current for the tail light & one to let more through for the brake light. The LEDs brightened considerably when braking with the tail light on, but only when looking directly at them (they were so bright that I saw red spots for a couple of mins afterwards!). So, not being able to get the correct brightness with different resistors I decided to cheat. There are so many different types of LED available that finding ones that work as I want could get expensive & take ages, so I bought a couple of those 1057 LED replacements that were running 12 LEDs. I took one apart, noted the resister values & that the LEDs were wired as 4 parallel chains of 3 LEDs. Fitting into the backup light (in a ring behind the red part of the lens) was easy enough & they looked OK as tail lights. When used as a brake light the step up in brightness was noticeable but wasn't good enough that I'd want to risk my life or the rear end of the Vette on it. Additionally, any traffic cop worth his salt would pull me over immmediately he saw the weak brake lights at night (or he could nick me for having exceptionally bright lights if he was looking directly at them). Fitting the other bulb into the rear light of a m/cycle gave much better results. I think the reflector in the rear of the light, coupled with the diffuser, helped there, but the Vette's back up lights have neither.
The truck lights sound good & I'll have a look at them. But I do need something that I can take apart as the lights will have to still hold an additional 21W bulb (for eather direction indicator or backup). I'm confident that I can do it, but finding the correct LED is the hard bit (once/if I do I'll post the make/model & resistors needed). I'll probably get a bulb that's used as a stop/tail & rip all of the LEDs out & mount them in my lights (that way somebody else has done all the hard work in getting the right luminosity & spread). It's easy picking resistors to control the current, but the brightness of different types of LED varies wildly, along with the viewing angle. Just to make it more awkward, it's a legal requirement for rear lights to contain a reflector, so some of the LED lights (complete) aren't an option.
My next step is an autojumble that's on soon. A guy sells LED bulb replacements that have 9 LEDS for the tail light (which, going by what I've done so far is more than adequate) & brightens them up along with switching on an additional 10 for the brake light. I reckon having the 9 LEDs facing directly backwards & then mounting the remaining 10 at angles slightly offset may get the result I want. Or just waste more time/money
