Wiper motor help
Old Apr 17, 2005 | 06:59 PM
majic1984's Avatar
majic1984
Default Wiper motor help
Alright guys.. sorry I can't post these pics on the forum directly but they're too big and I don't even have microsoft paint on this POS computer - so please take a look and tell me what you think.
Pic 1
Pic 2
How can I test to see if it works?
Are the ones at Autozone any good - what should I look for (I think I once read that the 71's had some sort of other wires to it)
Should I go get a remanufactured one - do these last very long?
Thanks for the help in advance guys!
- Michael
Old Apr 17, 2005 | 09:52 PM
EVIL_GRIM's Avatar
EVIL_GRIM
49-152 is the Napa part number. its made by Rayloc and they usually come in a flat gray color which i dont like that much. i plan on painting mine flat black. they seem to work great and if something goes wrong u can always just bring it back and get a new one.
Old Apr 17, 2005 | 10:03 PM
Vette Gator's Avatar
Vette Gator
I put in a rebuilt motor last Friday night. I didn't need to test the old one very much since it smoked when I hooked up the switch. Rebuilt was $50 from a discount place with a $3 core refund. So far so good.
Old Apr 18, 2005 | 10:47 AM
majic1984's Avatar
majic1984
Does anyone know if a 71 has some sort of year specific difference to the wiper motor - I heard there was some extra wire on it that I should look for?
Old Apr 18, 2005 | 11:14 AM
Vette Gator
There is an "extra" terminal apart from the three-terminal connector on my '76. This is a ground lead, and when I bought the rebuilt motor, it came without a cover, so I had to transfer the old plastic cover over to the new one, and also had to connect a copper strip to the motor body so that the "extra" terminal would provide a ground to this part as well. Is this is the "extra" wire you are referring to?
Old Apr 18, 2005 | 12:10 PM
markdtn's Avatar
markdtn
68-72 have an extra wire due to the wiper door. It is red and goes to the plug off the wiper door switch on the upper firewall.
Old Apr 18, 2005 | 02:04 PM
majic1984's Avatar
majic1984
This is the one I was referring to - do the ones at napa or autozone have this wire?
Old Apr 18, 2005 | 02:13 PM
1970 Dave's Avatar
1970 Dave
No, not unless your NAPA store carries a different one than it carries here--tis the wire to run the limit switch--to hold the wiper motor until the wiper door is fully opened. I don't believe its a mass produced part.
SEMPER FI--1970 Dave
Old Apr 18, 2005 | 03:08 PM
markdtn's Avatar
markdtn
I think they should. It won't work right without it. The ones from CarQuest have the wire.
Old Apr 18, 2005 | 04:29 PM
majic1984's Avatar
majic1984
Thanks much guys - this is what I once read here but can no longer find.
majic1984's Avatar
majic1984
Well then off to CarQuest I go and look for the little red wire
Old Apr 18, 2005 | 06:25 PM
68/70Vette's Avatar
68/70Vette
Maybe it's too expensive an option, but you can have the wiper assembly repaired/restored. I had mine done by Paragon. It cost $250.
Old Apr 18, 2005 | 08:04 PM
theandies's Avatar
theandies
If anyone comes up with a part number for the wiper motor with the wiper door switch wire from a national chain let me know. I need to replace mine also since the magic smoke came out of it a few years ago. I have a 1971 also.
John
Old Apr 18, 2005 | 08:30 PM
surfshark's Avatar
surfshark
I don't know if this is any help at all for a '71, but I put a wiper motor from a 1980 or around that year Monte Carlo on my '80 and it fits perfectly and works great with all of the settings from the switch. I put this on during my salad days in the early nineties. For whatever this is worth!
Old Apr 18, 2005 | 09:02 PM
majic1984's Avatar
majic1984
I wouldn't want to go this route because the wiper motor I have is not original anyways.
Old Apr 18, 2005 | 11:02 PM
markdtn's Avatar
markdtn
Probably OK for 74-82 but won't work right in a 68-72 because of the "extra" wire and delay functions. Without the wire the blades will be pushing against the wiper door until it opens. The motor won't last very long. Hollander 600C fits 73-90 Buick/Olds/Pont/Chev/Cad RWD fullsize, 73-83 Century, 82-83 Camaro/Firebird,73-77 Chevelle/ElCamino/GMC Sprint, 73-83 Cutlass/Grand Prix/Regal/Monte Carlo, 73-78 Eldorado, and 74-82 Corvette all w/o pulse. It says it will fit same cars with pulse by transferring pumps and covers.
Old Apr 19, 2005 | 11:16 AM
68sbShark's Avatar
68sbShark
I recently bought a wiper motor for my '68. It matched perfectly. Had all the right ground connections and all. It was a rebuilt from AutoZone and was about $55. They do a pretty lousy paint job on these, and the paint was flaking off before I even had the motor mounted. Oh well. It was still well worth it to see that wiper door go up and down!
Autozone part # 40-152.
Good luck.
~Rich
To Wiper motor help
Old Apr 19, 2005 | 11:30 AM
theandies's Avatar
theandies
Good luck.
~Rich
Thanks I'm off to Autozone.
Old Apr 19, 2005 | 11:39 AM
GaryS's Avatar
GaryS
Four years ago, when I bought my 72 I thought the wiper motor went bad on it. I checked at Advance Auto and they had the correct wiper motor, with the correct wire for the wiper door for around $70. The only difference was it was blue. The same shade of blue that your wipre motor is. I bought this thing, it plugged in normally and then I discovered my wiper door switch was out of adjustment. I had intended to strip the blue paint off of the AA unit and leave it natural aluminum so that it looked original.
Gary
Old Apr 19, 2005 | 11:41 AM
GaryS's Avatar
GaryS
Pic 1
Pic 2
- Michael
And I just noticed in your second photo that you wiper motor is a replacement - see the "REMFG" stencil. These things aren't that rare.
Gary
