Distributor troubles
Old Apr 18, 2005 | 07:30 AM
1974 C3's Avatar
1974 C3
Cruising
Default Distributor troubles
Any help would be great, ....here goes,...i have a 74 ...for about 4 years now ...you know the story, sat in a garage since 86,(last stick on the windshield) started every now and then ....60k miles....slowly redoing most of it myself (the easy stuff), and now getting to the have to send her out for service stuff, ...she doesnt seem to run as smooth as she should ....still has single points system (updated i think),im not at the point where i would jump in her and go on a two hour run ....runs alittle rough and has hard starts when she hot ....(starter blanket maybe needed?)....But as far a distributors go, do i go with a Rebuilt tach drive, ...or a Breakerless electronic kit or a HEI,..MSD tach drive with a 6AL box??? and what about new wires??? ... and then do i have to update the alternator? ... Or should i be looking at Carburetors??... i do at least one project a year with her (not all at once).. .and where is a good place to shop ....i mostly use Ecklers now.... any help would be great, ....thanks for your time.
Old Apr 18, 2005 | 09:14 AM
page62's Avatar
page62
Why not start simple (and save some money)...put a tune-up kit in your existing distributor. Points, condensor, cap and rotor. New wires and spark plugs would be a good idea, too. Get good quality stuff, like Blue Streak (Advance Auto carries this line.)
Get a copy of Lars timing paper at www.corvettefaq.com -- follow the instructions -- and the ignition system will be OK fine for now!
BTW: Hard starts when are often caused by too much ignition advance. Also, you may need to rebuild your carb at some point (not as hard as it sounds). If it sat a long time, it's likely gunked up. Don't be afraid to come back and ask for specific help!
Old Apr 18, 2005 | 02:50 PM
1974 C3's Avatar
1974 C3
Cruising
thanks for the help ........
Old Apr 18, 2005 | 03:41 PM
lars's Avatar
lars
There's nothing at all wrong with a properly set up points distributor - it won't limit your performance in any way. Upgrade it with a set of NAPA CS786 points with an RR175 condenser. If the engine is stock or near-stock, install a VC680 vacuum advance control unit and run it off a direct manifold vacuum source after setting up your total timing to 36 degrees. This will give you an outstanding ignition system and a great level of performance assuming that the other mechanical aspects of the car are good.
Old Apr 18, 2005 | 04:42 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i see no reason to replace an alternator if it is functioning properly.
Old Apr 18, 2005 | 04:47 PM
lars's Avatar
lars
If it's charging, it's fine. Nothing in the alternator should be worn out at 60K miles.
To Distributor troubles
