I’m trying to teach myself how this works, but my car is not nearby so I am looking at the AIM.
Each relay assembly has 4 ports. The 3 lower ports contain the valve; the middle connects to the engine manifold, the top and bottom connect to the headlight actuator. The upper port is the actuator that controls the valve.
My questions are about the valve’s actuator control. Does this receive vacuum only when signaled to open the headlights or vice versa? Is the actuator spring loaded to the top or bottom? Is the other side of the diaphragm balanced internally, vented to atmosphere, or sealed?
In the control system(the part of the system that gives the instruction), the absence of vacuum causes the positive operation. So when vacuum is removed from the valve, the headlights(or wiper door) open.
There are four hoses: 1) the control system vacuum hose; 2) the operating system vacuum supply; 3) The vacuum from the valve to the vacuum motor to open the mechanism, and; 4) the vacuum from the valve to the opposite side of the diaphragm to close the mechanism.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
To rebuild these relays, the hardest part is getting the ring that holds the upper half to the bottom half, off. When you get them apart you can see the spring under the metal cap that pushes the valve back to the closed postion when no vaccum is to the small upper port. The middle port on the valve body is where engine vaccum is applied at all times. The upper port is to raise the headlights when the vaccum is applied to the small upper port. The bottom port is to drop the headlights when the vaccum is taken away from the small upper port.
I got rid of the vacuum relays and installed the solid brass vacuum relays that are used on McDonalds hamburger grills; they're indestructable and fit in the same location--so invisable.
Where does one acquire McDonald's hamburger grill parts?
Any Taylor Freezer parts distributer; it's a model 32 grill. The valves operate on 12 VDC, so, when headlights are on, the valves are energized and the doors open.
I also use a small air compressor from an air horn instead of engine vacuum. This allows me to raise and lower the headlights with the engine off. easy hookup, just reverse the vacuum lines.
That is ingenious! How did you stumble onto the McDonald's fix? Surely you didn't look at it and say "Hey, I think model 32 grill vacuum relay will solve my problems." I really am curious as to how you came to the grill parts fix and am not trying to be a smartass.
Acutally, the headlights close when vacuum is applied to the OTHER side...
There are some good schematics in the shop manuals. I'll see if I can get a scan and post it...
This is what I was thinking. So the 'off’ position of the valve is to 'open' the headlights due to and internal spring? This is because there is no vacuum in the control hose (engine off, vacuum depleted).
Interesting to observe that the headlights do not pop up then close when the engine is first started. This is because there is some delay in vacuum reaching the valve (and therefore the actuator) as it takes a few seconds to evacuate the reservoir tank which is before the valve. The control line does not include the reservoir and therefore evacuates rather quickly.
I don't suppose you have any links/resources? This sounds like the perfect solution you've come up with here. I've scoured the Internet with no luck.
I am impressed. It also removes a whole bunch of crappy hoses. Its a hybrid electric-vaccum system. Electric to control but vaccum to do the heavy work.
