Temp sender going bad?
Old Apr 18, 2005 | 09:25 PM
Gordonm's Avatar
Gordonm
Default Temp sender going bad?
The temp on my car has been real cool recently. I checked it out today and with a temp gun I am showing around 170 to 185 at various parts around the motor. 175 right at the thermostat. The gauge is reading low and I checked it with an aftermarket gauge and it was showing only about 140 degrees. It has been working fine for 6 years previous to this but could there be corrosion on the threads. It does not look like any corosion and I change the coolant about every year and see no signs of anything bad. Or is it just a bad sensor. It is a different one than the stock because of the AFR aluminum heads but it has always read OK up until this year. Anyone have and corosion problems or sensor problems?
Old Apr 18, 2005 | 09:48 PM
62fuelie's Avatar
62fuelie
Sending units arew cheap. Try a new one.
Old Apr 18, 2005 | 10:39 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I had temp sensors go bad on me before... Not unusual..
To Temp sender going bad?
